2009 EX Sedan Brake Work - 4-wheel disc w/ ABS
824 Views 2 Replies 2 Participants Last post by  RVC14
I am looking for suggestions for replacement parts for my wife's sedan.Note this features 4 wheel disc w/ABS. Quality, durable parts is the goal. It is only street driven. This thread:
is good but lengthy and also appears to contain dated parts numbers. For example, it speaks very well of the Brembo Blank Rotors but I do not find the part numbers it states on the Brembo website. The part numbers I find on the Brembo website for her vehicle are:
Ft. 09.5457.31 ~ $50/rotor
Rr. 08.A147.11 ~ $46/rotor
Here is the webpage for the 2009 EX sedan: Shop - Brembo Store USA
If I purchase these I will simply use the pads Bremo recommends for them.
Additionally, when I removed the rear driver's wheel for inspection yesterday afternoon I found it very difficult to compress the caliper piston with a C-clamp. My Factory Service Manual does not cover the rear disc brake system. Do I need to exercise the ABS system to change rotors/pads on this vehicle?
1 - 3 of 3 Posts
The rear caliper piston does not compress like the fronts, but rather needs to be turned/screwed in because of the parking brake being back there. Get yourself one of these from local auto parts store for around $8 and save headache trying to use pliers to turn piston. Just make sure to clock the piston correctly so the pad pin will slide in the groove.
Automotive tire Motor vehicle Font Machine Automotive wheel system
  • Like
Reactions: 1
Actually, I already own one. I purchased it to repair a car owned by a friend of my wife several years ago.
My 8th Gen Civic service manual only covers rear drum brake vehicles.
I greatly appreciate you responding to my post. Time to order parts!
  • Like
Reactions: 1
1 - 3 of 3 Posts
