1 - 2 of 2 Posts
I've got a stock 09 LX-SR and one that has vexed me is that the engine will easily stall out at low RPM unless the clutch pedal is at least halfway down, and many times when I shift at around 3k RPM the clutch will re-engage fairly roughly unless I use total twinkletoes. The CEL is out and the clutch fluid is full.
I would first replace/bleed your clutch system (same process as bleeding brakes). If that is not the issue, you might be looking at a bad clutch.
Let's hope it is just air in the clutch lines.
1 - 2 of 2 Posts
