I just replaced the clutch and after I reassembled everything I went to start the car it will turn over (sounds like the spark plugs are out, no compensation sound) but will not start/run. The grounds are cleaned and have good contact. Could the car have jumped time?
Note: when I first tried to start the car it would just turnover but it never started up.
Thanks for the replies
I have two ideas:
Is the clutch disengaging?
Is the engine making compression? you can check this with a compression tester from amazon/any autoparts store.
Yeah check for compression, spark, and fuel. If you have all three of those then likely its something timing or computer related.
