Hello everyone,
Looking to upgrade my steering wheel on my 2010 civic lx Sedan - the rubber on my is completely cracked and breaking off.
Either way, i found a steering wheel on ebay from a 2007 CSX which says its compatible to my car.
Could i remove my current airbag and put it on this steering wheel, and would the steering wheel be compatible?
Super Moderator
From what I understand, the wheel is the same, only with an Acura emblem on the airbag. Regarding the airbag, the connector MIGHT be a hair different (clip), but it should work and you should be able to get it to clip on (airbag). I can't remember where I saw that.
You should be fine.
Report back with pics if you can. Good Luck
Thank for reply.
I ordered just the steering wheel without the Acura airbag. I plan on swapping my current airbag on this wheel. The wheel looks exactly the same as the OEM one so I am thinking it will work.
Currently waiting for it to arrive, will post pictures once its complete.
DIY - Done
Weekends have been a little crazy, wasnt able to install right away.
Removing steering wheel was incredibly easy after reading up a post on the forum. Went to advanced auto parts and purchased the steering wheel puller for like $12.00, and purchased a black honda badge since mine looked horrible.
Pictures are not the best, but here is a before and after
I didnt remove the paddle shifters from the steering wheel in order not to leave an empty whole. It looked really ulgy without them.
