1 - 15 of 15 Posts
· Registered
Hi I drive a 2006 Honda civic Ex. When my headlights are turned on they occasionally will Flicker. Actually all of my lights flicker interior lights, dash lights, taillights, headlights, etc. is this a common problem and how do you fix it.
· Registered
You might see some dimming when the rad fan, AC condenser Fan, blower, or other high loads are turned on, however flickering isn't normal.
I would start by checking the battery terminals, battery cables first.
· Registered
Yes but those things all use different grounding points. I would think more along the lines of it being a power problem, bad alternator or voltage regulator or even issues with the connectors on the underside of the under hood fuse box. If you have a voltmeter it would be interesting to see if the voltage fluctuates at the battery when it happens.
· Registered
2010 Si sedan 86k for sale
You can replace both of those parts on your alternator or for sixty bucks you get a new one, easy 2006-2011 Civic L4 1.8L 1799cc R18A1 OEM Alternator 11176 | eBay
1 - 15 of 15 Posts
