Thanks bud. That's what I wanted to know.acetech808 said:hey Ohsixcivic,
the speaker cover is part of the door panel.
webby said:
Any modern 6.5" speaker will fit in the door. The Distance from the inner door skin to the outer door skin is about 4".slimjim8481 said:Has anyone came across the max mounting depth for those front speakers? When I replaced the rears in my coup I had to make spacers out of 1/2" plywood. Then I had to cut off the end of the tortion bar on one side. I have also heard that you can cut out the factory speaker cone and use that plastic piece as a spacer to mount the new speaker in. Does anyone have any experience doing that?
probably the same way as the coupes. i have Polk DB650's in mymike114 said:Does anyone know how to change the front speakers in a sedan. Thanks
