1 - 8 of 8 Posts
2000 civic lx blower for heater- a/c won’t work on any speed setting the rear defroster won’t turn on nor will rec air. Checked fuses their all good
Check wiring behind the control panel for any loose wiring. Also check blower relay.
How do I check the relay? I’ve hooked the motor up straight and it works fine. I replaced the resistor and still nothing
Hooked motor up direct it works fine. Replaced the resistor still nothing so how do I test the relay. It’s getting costly buying parts I don’t need lol
As far as I know, the relay for the blower and the radiator fan motor should be of the same capacity. So in the fuse box, you can try to interchange them and check if the AC blower is working. If it is working, then you need to replace it else you need to look elsewhere for the problem.
Since you said that the rear defroster, recirculation and the AC modes also aren't working, suggest that you remove the panel from the dash and check for any connection issues before trying to replace anything.
Just tried something I saw on YouTube I unplugged the new resistor & ran a jumper wire inside the plug and it came on. The video states bad resistor if so I just purchased a faulty one
Discussion Starter #7
When the key is turned on to just accessories everything works just fine every time but when turn key on over an start car it stops working again
Discussion Starter #8
For what it’s worth to anyone I finally got the issue fixed. Of all things it ended up being the ignition switch. Dumb luck that I was able to get it figured out lol
1 - 8 of 8 Posts
