1 - 13 of 13 Posts
I was just wondering if anyone else has encountered this. When I'm sitting at the lights and it's time to go sometimes I can't put this baby into 1st gear unless I go 2nd gear first. I have a 2009 Si.
reminds me of my old Mazda MX3 you couldn't pull it out of first if your life depended on it.. it was like that god who pulled the sword from the stone or w/e :p
ya. happens to me, 09 FA5
manual says it's normal (and to shift into 2nd when it occurs than first), however, if it happens all the time, than to contact dealership
Discussion Starter · #7 ·
ya it happens about 1 in every 10 times. not a big deal... just wanted to make sure i didn't screw up my baby somehow.
Just curious. When you come to a stop and are waiting to go (such as at a stop sign or light) do you keep the clutch depressed? Or do you put it in neutral and let the clutch out while you are waiting, then push the clutch and put it in gear when it's time to start out?
You're blocked out of first gear if traveling above 15 *** (about 7 mph.) for best results, try shifting into first just before you come to a stop.
... and then sit with the clutch engaged until the light turns green/your turn to go?
(I stay off the clutch as much as possible. but that's just me.)
he said when he's stopped, so i figured he meant from 0mph
yeah, if your going anything above 4-5mph and shifting into 1st, that is going to be a bit rough, haha.
1 - 13 of 13 Posts
