1 - 11 of 11 Posts
1. 18x8.0" BBS style Rims + Falken Azenis st115 tires.
2 rims have 1 spot of curb rash on each, barely noticable look at pics, other than that the rims are immaculate! Real authentic BBS centercaps! Tires are 90% all around, $1000 Firm
225/40/18
offset-40
Width-8.0
bolt pattern- 5x114
located oshawa ontario!!
2. 2009 si clutch and pressure plate with 7xxx km on it. $100
3. 2006 si exedy replacement clutch and pressure plate, used but 50% life remaining- $60
4.Exedy 9lb lightened flywheel for k20, would recommend resurfacing due to it was heated up from a clutch. $100
5.2009 civic si k20 ecu, 7xxx km- $150
6.2006 si cluster 140km- $100
7. 2006 k20z3 engine, 140km, good compression ran perfect when taken out. comes with full wiring harness and all sensors..just motor no tranny. $2000
8. Blox Shift knob- $50
9. 2009 civic si shifter cables 7xxx km- $80
10. 2009 civic si shifter assembly 7xxx km-$80
11. 2006 si stock cd player- $40
12. Boston acoustics 12" sub single 4 ohm. 250-1000rms. 2 available,mint. $100 each
13. 1 farad capacitor-$40
14. Focal Polyglass 6x9's visual 7/10. work great. $80
15. JBL GTO1004- # Grand Touring Series 4-Channel Class AB Car Amplifier
# RMS Power Rating:
* 4 ohms: 100 watts x 4 chan.
* 2 ohms: 150 watts x 4 chan.
# LED power and protection indicators
# Tuned Bass EQ (0-12 dB bass boost)
# Bridgeable operation
# Preamp RCA outputs
# Cast-aluminum heatsink
# Variable high-pass filter (32-320 Hz, 12 dB/octave)
# Variable low-pass filter (32-320 Hz, 12 dB/octave)
# CEA-2006 compliant amplifier
# Frequency response: 10-100000 Hz
# Dimensions: 18-9/16"L x 10-3/8"W x 2-1/8"H
# 4-gauge power and ground wiring is required for installation.
$200
16. Rockford Fosgate Punch P550.2 -# 550 watts, Punch Series 2-Channel Amplifier
# RMS Power Output:
* 4 Ohms: 150 watts RMS x 2 chan.
* 2 Ohms: 275 watts RMS x 2 chan.
* 4 Ohms Bridged: 550 watts RMS x 1 chan.
# Variable high- and low-pass filters (40-400 Hz, 12 dB per octave)
# Wired Punch Bass EQ (0-18 dB at 40 Hz)
# Focused Mass Heatsink design
# Removable connector cover
# Special-design TO-247 MOSFETs run cooler than standard transistors
# Preamp inputs and outputs
# Fuse rating: 30A x 2
# 4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
# 13-3/4"W x 2-1/2"H x 11-1/8"D
$200
if you need more pics of anything send me your email, located in Pontypool Ontario. Might be willing to meet up in gta.
Pics Coming!
CHOO-CHOO!!!!!!
:fistpump:
your really really really making me want to drive out and see you!... AGAIN.
all those parts together would make a mean golf cart!
1 - 11 of 11 Posts
