1 - 16 of 16 Posts
i just picked up some work emotions and one pair is concave. i would like to run these up front, will it rub with 245/40/17 tires? -1deg camber, eibach springs. can't wait to get these on my car! thanks
these are the wheels i got :D
i forgot to mention that they already have almost brand new 245/40's mounted on there, thats why im asking if i can run them.
It might work. I'm running 17x8 +45 with 255/40. Lowered on HFP and no camber up front. I had to tuck my fender liner under the tab or it would rub on extreme dips in the road. I don't rub at all anymore.
Discussion Starter · #9 ·
well without spacers the wheels were hitting the struts. i bought some grade 8 1/2" opening flat washers, they are 2.32mm thick. they worked perfectly, no more rubbing on the inside of the strut, even thou its very close.
i tucked the fender liners under the fender tabs and bent the tabs up, no rubbing even when turning the wheel to full lock. they look awesome on there! thanks guys!
Discussion Starter · #13 ·
just a little update for those who try this setup:
the inside of the front passenger wheel was rubbing on the strut, only when turning. i guess the suspension geometry changes enough to allow the wheel to move in closer to the strut when the wheel is turned. I simply added another 2.3mm washer to each of the lugs on both front wheels. (now about 5mm (4.6mm) total)
It was happening on the passenger side only because I have slightly more camber on that side (1.6 deg as opposed to 1.4deg on the other side) we couldn't get it any closer when on the alignment machine.
I am going to go back for a new alignment soon because it has changed with the new wheel offsets and wider wheels.
bump from the dead....Any problems rubbing the fender? I have the same wheel specs except for a 38 offset and I would like the widest wheels possible without pull/shave/roll. I'm lowered on Tein s techs w/hfp shocks.
^ You are using the same tire size also 245/40/17? Id go down to a 235/40/17.
Since your not on coilovers you'll prob rub on dips in the road your gonna need some -camber up front and maybe a 5mil spacer to clear the strut. You might not as your using the stock strut still. Im running 17x9 +37 on 235/40/17 tires on coilovers and i can barley slide a key between the strut and the tire. And i had to roll the fenders and tuck the liner not to rub.
So do you think id be okay if i had 225/45/17 on 12x9s?
i rolled the fenders and tucked the liner already...im on tein flex coils
1 - 16 of 16 Posts
