1 - 7 of 7 Posts
Whats good everyone .. i bought my car used and it had 17inch rims on it and im thinking about putting 18inch ,.. would i have to change the suspension? and what else would i have to change?
18" rims need either 215, 225, or 235/40-18 tires. Because manufactures vary slightly in size in width, I would suggest 225/40-18 tires to be safe. Also , you need to have the proper offset which should be around +45mm depending on the width of the rim. Since you did not tell us what car you have, if you have a LX with drum rear brakes, make sure the rim will clear them. If you have a hard time understanding what I just explained, tirerack.com has a awesome technical section.
1 - 7 of 7 Posts
