Wow Mike....how can someone with obviously so much invested in their engine have such poor grammar, reasonining, and comprehension?
Let me break down your manifesto of stupidity for you:
"guess what after 15000 miles without an oil change i wouldnt even have oil left in the car , and yes i can prove this since i run 5.5 qrts for each change and get at most about 4 back out and i empty a catch can about once every 6 weeks "
It's called top-off...you don't just run 15,000 miles without ever checking your oil. You top it off as you consume. I'm running a stock car; I would think it would be obvious that different rules apply to different situations. But apparently you think it's wise to compare my stock car choices with your heavily modified choices.
"he asked if he'd be ok with 10/30, and yea if i can run in my engine , Ohhhhhh by far he can, so correct me if im wrong but was he given an answer .... Ummmmm yes he was ... does even a excellent synthetic break down in a high revving motor? Hell yes it does"
I didn't dispute your assertion that he could run 10w30, I disputed your assertion that "our cars rev so high that they break oil down quickly anyway". It's an oblivious statement. Do you read my response? Our engines, without ridiculous levels of modification, are actually quite easy on modern oils. They don't dump fuel into the engine (like a VW 2.0t). They don't mechanically shear down oils quickly. They run clean.
So my point was that our high revving engines actually do quite well under the stock maintenance minder with even dino oil.
"Hell yes it does, so maybe if your driving slower than my grammy in her Elantra and keeping the rpms down to a minimum then id love to see your oil at 15000 mile change intervals"
Ok, here's my oil after 14,500 miles. By the way, I shift at 4000-5000 rpms and redline a few times each way to work. Not exactly granny driving.
06 Civic SI - 14.5k UOA on AMSOIL SSO 0w30 - Bob Is The Oil Guy
Whats that you see? Evidence to back-up my claims. Couldn't be!?!?
"also if you take a good look at the design of any of Hondas DOC motors you would realize they are designed to drop the bottom cam out during vtech and eliminate the dumped oil out the exhaust via PCV valve connected directly to the manifold and the tube coming off your valve cover to the air intake also sends waste oil out the valve cover to be burned out the exhaust, so I guess you stay out of the vtech in the car or the oil in your car wouldnt make it 15k"
I don't know whether to laugh or cry at this passage of idiocy. Again, it's called top-off good sir. You keep your car topped off with oil. Try it out.
"I would also urge anyone to never take the advise of someone saying running a vehical of anykind with the same oil for 15000 miles as a teacher of any sort"
Really? So I guess all the modern vehicles that do 15,000 mile oil change intervals using synthetic oils with their OBC's are completely off base....such as the current crop of MINIs, BMWs, and many others?
Or perhaps it's that you have no idea about oil life, despite your knowledge of other things?
"my car even with an oil cooler ranges aprox 315, so if your going to suggest that i run the same oil for 15000 miles "
No, I'd suggest you look into getting your oil temps down because no modern oil is going to fare well at those temperatures on a daily basis. Not even the top notch synthetics. It's why BMWs and Infinitis go into "limp home mode" at 300 degree oil temps....because the oils start to have sharp failures resulting in engine failure soon thereafter....and those cars are running high quality synthetics.
I'm really happy you have a car running 14:1 compression. Why again did you think I was "recommending" you run 15k on your oil? If your read again, you'll notice I was pointing out my personal experience with oil analysis on our engines debunked your theory that our engines are hard on oil.
I recommend people run 15k mile oil changes through careful research and application, if they want to try it out. But it's not just a "Yeah, throw the oil in your engine and start driving".
Let me know when you master reading comprehension and analysis. I look forward to us continuing our discussion then Mike
Joe
