1 - 20 of 20 Posts
Ok I am ready to make the plunge, I have a stock Greddy kit now, with stock tune from Greddy (which sucks by the way). I am going to take my car to AJP and have them install a 3 inch test pipe, boost controller (turned to 10), 440cc injectors and then have them dyno tune my car for 10PSI.
Here are my questions: Do I really need the rest of the 3 inch exhaust or will just the test pipe alone work for this mod. I really dont want to replace the rest of the exhaust. Is there anything else I might need for this? I will not be a BOV due to all the issues folks have with them that are running this kit.
My car is an 07 with everything stock except the Base Greddy kit.
Thanks
you dont need the 440s... i have the 370s and run 10.5psi allll day and still have enough fuel...
oh and btw.. have fun with the MAF sensor..
and you should get an exhaust too.. there is really no point in getting your car tuned to that amount of boost without a better way to get all that air out of the motor..
Talk to me about the MAF sensor 06civSi, Let me find out that at only 10.5 psi, you maxed it out. Remembering my wrx, I maxed it at 324hp and had to get a perrin 3" Maf housing so that more air could be flowed.
how are you making anything over 300whp with 370cc injectors????????? 550's only take you to 330 so you cant be making any good power with 10.5psi on your kit then.
:biggrin: Not me thank goodness....BUt I read ALOT, and for the first time in my life I retain this information...I wish I could have in school, but I guess this is better. :thumb:
How much hp u pushing to the wheelZz with that set-UP
The 3" test pipe won't mate to the stock exhaust mid section unless they do a stepdown to make it work. That will be a huge bottleneck there though if you leave it. If you are strapped for cash, just do a 2.5" dp and step down to the stock exhaust midsection which is 2". Later on ditch the stock unit for a nice 2.5" cat back system then you'll have 2.5 all the way back.
For as much power as you would want to make on a stock block, I would personally go with a 2.5" all the way back with a hi-flow cat. Also weld/have someone weld an extra o2 bung and invest in a wideband if you haven't already (UEGO or LM1...). Like said earlier too if you're strapped for cash just get a 2.5" downpipe for now and add the rest later.
1 - 20 of 20 Posts
