1 - 20 of 151 Posts
Daily Driven FG2
Owner - John Chavez(jchavez)
Builders - Daniel Butler(palmerblock)<---Engine Builder, Ryan Zamora(0ecko01)
Church Automotive Dynapack - orange(pump gas) teal(race gas - ms109)
MD Automotive Dynojet - all were on pump gas
...fyi, the pumpgas plot on church's dyno and the plots on md automotive's dyno were done within 1 hour of each other on the same day, same calibration, no changes made to accomodate either dyno
Correction - SAE
...this just shows our dyno reads on average 7% higher than a dynojet
Some details below:
-Core - K24a2 (TSX)
-K24a2 block, diamond bore/hone to fit the 87.5mm CP Pistons
-K24a2 crank balanced and polished by Castillo's Crankshaft Specialist
-CP X-Forging 12.5:1 Compression Pistons (Barrier Coating on the dome, Proglide Zylene Anti-Friction Coating on the skirt)
-Crower 4340 Connecting Rods no chinese rods here
-Rotating assembly balanced within 1/4 gram
-ARP Head Stud Kit
-OEM Honda main and rod bearings (spec'd with dial bore guages and micrometers, no plastic guage **** here)
-OEM TSX head gasket
-Hybrid-Racing Fuel Rail
-ATI Crank Damper
-TODA Heavy Duty Timing Chain Tensioner
-Hytech Oil Pan Baffle in K20Z3 oil pan
-RSX Type-S oil pump
-Prototype Racing Oil Pump Spring Mod
-RBC ported/bored intake manifold
-OEM Honda 2010 Acura TL 3.7L DBW TB bored(81mm air intake side to 72mm intake manifold side)
-Portflow Design Head k20z3(09 Civic Si)
-Drag Cartel Stage 4 Cams
-Surpertech springs w/titanium retainers
-Honda RDX 410cc fuel injectors
-Skunk2 Racing Header
-3inch exhaust
-TODA lightweight flywheel, clutch disc, and pressure plate. (The entire assembly is balanced on a dynamic balancer to ensure reliable high rpm operation.)
-Hondata intake manifold gasket
-Hondata Flash Pro with Tuning by Church Automotive (Daniel Butler)
Any Questions?...Any Answers?...
Just got my GO pwr k24/k20 put it, Its lovely. I need to get my IM ported and bore my Tb to let it flow a little better.
Thank You
:clapping:
Daily Driven FG2
Correction - SAE
Some details below:
-Core - K24a2 (TSX)
-ARP Head Stud Kit
-ATI Crank Damper
-3inch exhaust
I can't express enough thanks to Ryan and Daniel for all their hard work to make this build happen. Like Ryan originally said... 300 HP here we come.......
:clapping:
I've had the car back for about 2 weeks and 600 miles later... it was sooo....worth the wait. Thank you both again...
Who would've thought 300HP NA pump gas daily driver was possible?
All that I can say is that you boys built me a beast... Civic on the outside.... all motor monster on the inside.
What's next guys?
:clapping:
:clapping:
What's next guys?
100 shot of nos...:vtec:
:clapping:
:clapping:
What's next guys?
I would order a custom k24 header from Hytech. You have already went all out in every other part imagineable. Might as well go for broke.
Wow, that's nuts, I'm surprised those 410 injectors can handle that.
Wonder if you would benefit from a custom 4-1 header?
Stage 4 cams in a k24???? aren't you suppose to make more power than that? 295whp on a dynojet is kinda low for what you have. you should be like 330whp on a dynojet with that setup.
1 - 20 of 151 Posts
