06 si. new head & gasket, still losing coolant ;(
1248 Views 2 Replies 3 Participants Last post by  vis1onero
Milky oil so I serviced engine & turns out head was cracked. Replaced the head & gasket along w it. Continuing to lose coolant, 300 miles later oil still looks clean. I’ve noticed when taking radiator cap off, no pressure is being released. Any ideas & suggestions??
Coolant system not pressurized -> higher temps -> evaporating coolant??
What I’ve done:
  • bled coolant system (looked good enough, maybe not?)
  • new thermostat
  • new radiator cap
  • pressure tested outside autozone, no leaks.
1 - 3 of 3 Posts
What I’ve done:
  • new thermostat
  • new radiator cap
ScottieKilmer.com
What I’ve done:
  • new thermostat
  • new radiator cap
did you ever find out the problem? is it going out the tailpipe you think?
1 - 3 of 3 Posts
