08 r18, need to replace shocks, upgrade? - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Suspension and Brakes
Old 07-17-2018, 01:37 PM   #1 (permalink)
Swampcrawler has their car in neutral right now
iTrader: 0 reviews
My 08 bottoms out on just about every bump I hit. I need to replace shocks.
Can someone give me the run down on what components need to be replaced (shocks, struts, springs?) and is there something I should go with that will offers an improvement in handling over stock?
This is just my DD, but I’ll be stuck with it for a while so I’m considering doing some mild upgrades for a bit more fun on the street.
Swampcrawler is offline
Old 07-17-2018, 04:01 PM   #2 (permalink)
dave777 just put it into 1st gear on 8thcivic
iTrader: 0 reviews
They actually make something called quick struts which is the complete assembly (strut, spring, and strut mount, and all the hardware)
I recommend KYB Strut Plus for the front, along with KYB shocks for the rear.
ANYTHING will offer an improvement over your stock--blown--shocks
dave777 is offline   Reply With Quote Quick reply to this message
Old 07-22-2018, 09:05 AM   #3 (permalink)
TDJohnson75 just put it into 1st gear on 8thcivic
iTrader: 0 reviews
Replacing the struts and shocks is pretty straight forward.
Just pickup or borrow a set of coil compressor to disassemble the struts and you are good to go.
Be mindful of the struts mount orientation when removing and installing them.
If installed incorrectly, you will know it from all the clattering and popping noises lol
So quick recap:
Replace strut mounts
Replace struts
Replace rear shocks
Replace front and rear sway bar end links since you are doing the shocks, they wear out at the same rate of the shocks.
I would suggest KYB for replacement as they are OEM spec’d and provides a tiny upgrade factor.
Sent from my iPhone using Tapatalk
TDJohnson75 is offline   Reply With Quote Quick reply to this message
Old 07-24-2018, 07:06 AM   #4 (permalink)
fasto82's Avatar
fasto82 just put it into 1st gear on 8thcivic
iTrader: 1 reviews
i have an HFP kit form my 08 r18 that has a little less than 20K miles on it. $250 if you are interested. mine was a 2 door. i took it off to replace with a megan racing coilover set up. you wont have to worry about a spring compressor and it upgrades the suspension beautifully! i need to clear out some old parts so please buy these and my wife will be happy! lol
fasto82 is offline   Reply With Quote Quick reply to this message
Old 08-26-2018, 06:13 PM   #5 (permalink)
Hondararri has their car in neutral right now
iTrader: 0 reviews
Fasto82 I believe the coupe will not fit my FA5 ? if it does what’s the difference in spring and shock set from an SI ? Mine has 208k and looks to be original or Oem replaced.... I’d be interested in said parts if you ship to 27571 NC ? Not trying to thread bust either...
Hondararri is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
You may post new threads
You may post replies
08 fa5 koni uneven height after rear shocks install albertlevan Suspension and Brakes 2 10-05-2017 06:29 PM
need to replace rear struts on an 08 si. parts question. 9ballprodigy Mechanical Problems & Technical Chat 1 04-27-2017 10:04 AM
2008 r18 - noisy power steering pump - replace o-rings without removing? lpranal Mechanical Problems & Technical Chat 2 11-11-2016 10:19 AM
