06 Coolant Drain Bolt on Block: Awkward position? - 8th Generation Honda Civic Forum
Old 07-04-2019, 10:20 AM   #1 (permalink)
crypticlineage just put it into 1st gear on 8thcivic
iTrader: 0 reviews
I am doing coolant drain and refill today. The factory manual specifically suggests, in addition to draining through the radiator pet****, opening up the 28mm drain bolt on the engine block.
While I can easily reach the bolt, it's sitting right on top of an electronic/electrical connector. So if coolant drains out from that position, it's going to wet all the electronics around there. Is it possible that just removing that bolt allows coolant to be drained into radiator and then it will come out of the pet**** too?
If that's not true, I am baffled at the idiotic design of this drain plug. Can anyone chime in?
crypticlineage is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
You may post new threads
You may post replies
