The AC shim "trick" DOES work - 8th Generation Honda Civic Forum
Old 05-09-2019, 08:25 AM   #1 (permalink)
Lexbrett has their car in neutral right now
iTrader: 0 reviews
Hi All.
Haven't been active in a while, but I just wanted to briefly share my experience fixing my wife's 2011 Honda Civic AC. The AC was only intermittedly working, and less so when it was hot outside. I saw a few posts indicating that the space between the clutch and electrostatic magnet increases over time, causing the clutch not to engage.
The next time the AC clutch did not engage, I just stuck a big wrench down there and pushed on the clutch and it ENGAGED, confirming the space was too large.
The TRICK is removing the AC clutch and removing the shim. It just plain works, and I probably saved myself a small fortune. There are several useful DIYs out there you can reference.
Good luck!!
Lexbrett is offline
Old 05-09-2019, 11:38 AM   #2 (permalink)
Super Moderator
EdNaviEx's Avatar
Ed
EdNaviEx just put it into 1st gear on 8thcivic
iTrader: 1 reviews
I heard over and over that removing the shim (i understand there is only 1 or 2 or them) makes the A/C clutch engage and work like before. However I would like to add the question, how much time/mileage does this work? I had mine go last year and I had something like 250K miles on mine. I ended up getting a new A/C compressor (with new clutch) on amazon for less than $300 (denso). Cost me less then $100 to get it recharged (indy shops may charge 100-150 for same service). $400 isn't bad for a new compressor/new refrigerant in my book.
Good to hear things worked out for ya, thanks for sharing and good luck!
EdNaviEx is offline   Reply With Quote Quick reply to this message
Old 05-14-2019, 02:42 PM   #3 (permalink)
iTrader: 0 reviews
I don't know how long it will last, *fingers crossed*. But it seems logical that the AC should continue working as long as the clutch engages. My wife's car has 159,000 miles on it, so if it gets through one or two more summers, I'm good.
There is also the option of replacing the clutch altogether, which is no harder than the job of removing the shim.
BUT just to be completely honest, the DIY video explaining removing the shim was a massive oversimplification. The video said the whole job would take 1 hour. It took me 8 hours. I had to experiment with the correct shim size, and each time I did it involve removing, testing, etc.
Lexbrett is offline   Reply With Quote Quick reply to this message
Old 05-14-2019, 07:07 PM   #4 (permalink)
Adam Knight
itcrackerjack just put it into 1st gear on 8thcivic
iTrader: 0 reviews
Yeah, those clutches do wear down so this makes sense. It's just a way to squeeze a little more toothpaste out of the tube before getting a new tube. My wife's ody had the clutch/stator keep going out. I replaced it 3 times for $100 when if was finally determined that the compressor bearing was shot. It was worth it over as by the 3rd time I replaced the clutch in less than an hour.
itcrackerjack is offline   Reply With Quote Quick reply to this message
Old 05-16-2019, 03:42 PM   #5 (permalink)
iTrader: 0 reviews
Yeah that clutch removal definitely has a bit of a learning curve, but it gets so easy once you have done it a few time. Indeed, I am getting that last bit of toothpaste out. I'm just amazed the "trick" actually worked. These types of forums are amazing..
Old 06-04-2019, 05:13 AM   #6 (permalink)
elsonhuge just put it into 1st gear on 8thcivic
iTrader: 0 reviews
The AC clutch in mine was also slipping. I tried replacing the relay and it worked - no more slipping and cold air was continuously blowing again. Next time, if my trick does not work anymore, I will try the shim removal trick.
elsonhuge is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
You may post new threads
You may post replies
Trusted source for AC Clutch for 06 Civic Si Chalt Mechanical Problems & Technical Chat 12 08-15-2018 03:33 PM
AC compressor alway on 2010 SI K20jas Mechanical Problems & Technical Chat 1 07-06-2018 10:54 AM
2008 DX-G ac compressor and fans won't work jimmyw.1987 Mechanical Problems & Technical Chat 0 06-13-2018 08:58 AM
2007 Honda Civic Si, intermittent AC dilemma solved. RoyBoy808 Mechanical Problems & Technical Chat 0 03-06-2017 02:57 AM
Rodents chewing wires, now A/C won't work AnonymousPirate Mechanical Problems & Technical Chat 5 11-17-2016 04:07 PM
