'08 Stumped on Full Dash Removal - 8th Generation Honda Civic Forum
Old 04-19-2019, 08:35 PM   #1 (permalink)
keems06 has their car in neutral right now
iTrader: 0 reviews
Hello all,
I'm deep into a heater core replacement and I've reached a roadblock and was hoping some of you could help me out.
I've removed all dash trim pieces. Center console, pillar trim, kick plates, everything (see photo). I've removed the 3 dash support bolts from the driver's side, 2 from the lower center console area and 2 from the passenger side. From the Haynes manual and DIY article I've seen on this form, it sounds like the dash should slide up and backwards, however it will hardly budge.
I've gotten it to move very slightly back on the passenger side, and it seems loose on the driver's side. It seems like it's being held up in the middle somewhere. Is there some hidden fastener that I'm not thinking of? It looks like there is a pin located on left and right sides of the dash that it hooks onto. It appears I've cleared that, it just won't move any further.
As you can see, I've resorted to attaching ratchet straps to the dash and trying to pull it out using the rear car seat latch system. (I'm desperate)
Is the entire upper gray portion supposed to come off before the "dash" is removed, or is that all one unit? Any help would be greatly appreciated. I may even put together a proper how-to if I can get this finished.
Full Dash Photo:
Drivers Side Bolts are Removed:
Passenger Side Bolts are Removed:
Lower Center Support Bolts are also Removed:
Thanks
keems06 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
You may post new threads
You may post replies
Speedometer dash piece removal? JacobCory Inside and Out 7 10-02-2016 05:21 PM
