2006 Civic Si in Limp Mode after clutch replacement - 8th Generation Honda Civic Forum
Old 04-26-2018, 08:47 PM   #1 (permalink)
Honda5eva has their car in neutral right now
iTrader: 0 reviews
Car: 2006 Civic Si
Miles: 124,000
Mods: DC Intake, innovative mounts
Hey so I just replaced my clutch a flywheel with an exedy kit from amazon, which came with a 10lb chromoly flywheel. Everything seemed to go smoothly, car shifts smooth, engine idles smoothly and clutch disengages fine and all that.
But now I have a CEL, and a red battery light on, and the car won't rev past 3000 (aka limp mode). I have no idea whats causing this, I've checked all connections and grounds and everything seems fine. I have multiple CEL codes after getting a scan at Oreily's.
Codes:
P0102 - Mass Air Flow A Circuit Low Input
P0340 - Camshaft Position Sensor A Circuit
P0141 - O2 sensor Heater Circuit Bank 1 Sensor 2
P1298 - Electric Load Detector Circuit High Input
P16BC - Generator Connector Disconnected
61-1 - Battery Voltage Malfunction
C1555 - [Mitsubishi] Steering angle SNS. out of range.
Honestly I don't know where to start. The car was kind of abused by the previous owner so I'm trying to bring life back into it.
One thing to note is I jumped the Clutch Interlock Switch with a paperclip, because the car wouldn't start after I adjusted the clutch pedal, but I had the CEL before I did this.
Honda5eva is offline
Old 04-27-2018, 12:41 AM   #2 (permalink)
MRBOOST_915 just put it into 1st gear on 8thcivic
iTrader: 0 reviews
Check your grounds. There's one on the tranny and passenger side. Also wireharness in the front under the intake manifold make sure everything is connected properly..
MRBOOST_915 is offline   Reply With Quote Quick reply to this message
Old 05-04-2018, 05:21 PM   #3 (permalink)
iTrader: 0 reviews
Went through all the plugs again. One of the wires for the tranny plugs was frayed, and it was shorting out. Re-spliced the wires and everythings good to go. Random ****.
Honda5eva is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
You may post new threads
You may post replies
What are non-SI coupe and sedan spring rates? Internet info is very inconsistent scott4 Suspension and Brakes 0 12-11-2017 11:36 AM
Budget suspension upgrades for the Commuter scott4 Suspension and Brakes 5 12-10-2017 05:05 PM
2006 civic radio in 2006 civic SI Brandon2006civicSI I.C.E., Electrical, Security, & Navigation 2 12-07-2017 04:21 PM
Need advice - Selling Honda Civic SI 2006 as is or replace clutch? moosehead Mechanical Problems & Technical Chat 5 08-27-2016 08:45 PM
