Power Steering (Hose?) Leak - 8th Generation Honda Civic Forum
Old 08-05-2017, 09:31 PM   #1 (permalink)
Bramrock's Avatar
Richard Brammer
Bramrock just put it into 1st gear on 8thcivic
iTrader: 0 reviews
Hey guys, I noticed a few months ago my car would start making an aggressive whining noise on startup and while driving that would go away over time, I assumed it was my alternator going bad but I eventually noticed the whine would sharply increase with the turn of my steering while. At that point I assumed it was something to do with the power steering and sure enough when I checked my levels were low, I bought some fluid from Honda and topped it off and like magic it was gone (too easy to be true).
A few months later the whining came back so I finished off the bottle to get it back to level but then it dawned on me that my levels should not be dwindling that quickly, sure enough I noticed a pretty decent oil based product leak on the floor (had seemed to be accumulating for a long while I always park in the exact same spot).
I checked the forums and EVERYONE would make thread about it being the pump or the O-Ring, but in my case I think it's the High Pressure hose (specifically the metal bit that runs between the two front wheels).
I'd appreciate if anyone could help me diagnose the issue. I'll attach a picture so you can see what I'm referring to
Bramrock is offline
Old 08-13-2017, 10:47 AM   #2 (permalink)
Bramrock's Avatar
Richard Brammer
iTrader: 0 reviews
Welp, thanks anyway guys
Bramrock is offline   Reply With Quote Quick reply to this message
Old 08-13-2017, 11:13 AM   #3 (permalink)
Super Moderator
EdNaviEx's Avatar
Ed
EdNaviEx just put it into 1st gear on 8thcivic
iTrader: 1 reviews
Can't really add much to your issue, but I would start there (high pressure hose) and quickly. Appears as though where it's leaking on the "frame", there is oxidation.
I had an issue years ago, but it "cured itself". Problem only happened when it was cold. I can't explained it.
Good luck! Report back on any findings!
EdNaviEx is offline   Reply With Quote Quick reply to this message
Old 08-22-2017, 09:07 PM   #4 (permalink)
RickNJ just put it into 1st gear on 8thcivic
iTrader: 0 reviews
Did you replace both the O-rings?
RickNJ is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
You may post new threads
You may post replies
Power steering leak 2006 CIVIC LEAKING P.S Mechanical Problems & Technical Chat 4 07-12-2017 11:05 AM
Stiff Power steering KrustyTheClown Mechanical Problems & Technical Chat 0 03-04-2017 02:15 PM
Potential Exhaust Leak and Mechanic Referral atnchn Ontario 3 02-04-2017 10:32 AM
2008 r18 - noisy power steering pump - replace o-rings without removing? lpranal Mechanical Problems & Technical Chat 2 11-11-2016 10:19 AM
Smaller diameter power steering pulley (R18) 2poler Engine Swaps, Mounts, Pulleys 0 09-28-2016 06:47 AM
