2007 Civic EX R18A1 Serpentine Belt Tensioner Bolt - 8th Generation Honda Civic Forum
Old 05-30-2017, 05:52 PM   #1 (permalink)
Bruce Bennett
Brewster_440 just put it into 1st gear on 8thcivic
iTrader: 0 reviews
Iím looking for information on changing the serpentine belt tensioner on my 2007 Civic EX with the R18A1 engine. I know about the recalls, where the belt routing was changed Ė as the belt tensioner bolt could break when it has too much stress, TSB 09-007.
Iíve done some research on this since evidently there are some issues with changing this part Ė and it mostly boils down to the pivot bolt. On the internet Iím finding everything from a little girl changing this with absolutely no troubleÖ Ė to people asking how hard it is to replace the engine block because their bolt is broken and Hondaís solution is to replace the block (Holy Crap!).
Iíve had the part on my workbench for a few months (Gates tensioner and belt set) and Yesterday felt I had enough knowledge to get under the hood. Iíve been working on cars since the mid 70ís, mostly big block Chrysler, some small block and sixes too, but this is my first Honda.
Bought it in 2015 with 136K on it, now it has 218K, and I paid cash Ė no idea of maintenance records. Got this belt and tensioner from Rock Auto and for a 2007 itís GATES ACK070852. Interestingly if you look up for a 2006 itís GATES 39054K and comes with a bolt.
So here is what I didÖ
Pulled the passenger wheel/tire and plastic shield, and negative battery cable. Loosened the water pump pulley bolts, removed the serpentine belt, sprayed some PB blaster down the back of the tensioner wanting to get that into the bolt threads, removed the alternator. Now Iím down to the tensioner, and yea, can shake it around as the bushing is worn where it mounts to the block with this notorious 8mm hex cap head mounting bolt. More PB blasterÖ
got an 8mm allen socket on my 3/8 ratchet. Itís a craftsman fine tooth flex head ratchet so itís a few inches longer than a smaller shorter standard ratchet Ė has a bit more leverage like a 3/8 breaker bar. This bolt is supposed to have 40 pound foot of torque on it. That bolt does not want to budge. Gave it some more PB blaster and even gave the head of the bolt a few taps with a hammer through the 8mm allen socket. Bolt still wonít move. Last thing I want to do is break this bolt. I read on a post with a guy changing his water pump that he put a piece of pipe on his ratchet and got his bolt loose and it was super tight, but Iím not doing that, because MY bolt will break.
Brewster_440 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
You may post new threads
You may post replies
2007 Civic EX MT Coupe engine noise? Jmaclicious204 Mechanical Problems & Technical Chat 2 04-26-2019 06:54 AM
Rear Upper Control Arm Replacement - 2007 Honda Civic Ex Coupe Sengx1 Mechanical Problems & Technical Chat 4 02-05-2019 05:37 PM
Replacing Belt Tensioner tbirdman Mechanical Problems & Technical Chat 11 06-01-2017 11:29 PM
2007 Ex - Shuts off while driving. Need help labmixz Mechanical Problems & Technical Chat 5 11-28-2016 07:54 PM
2007 Honda Civic Ex (R18) - brake problems jellyphish Suspension and Brakes 3 10-28-2016 12:58 PM
