So I installed Nokya Arctic Purples in my wifes Civic. I used the harnesses all around. My question is, the DRL's aren't as bright as stock. I love the color of the lows and highs. They look just like HID's!
You are not gonna get the same output on dem' Nokyas as you did on the stock bulbs.Pretty much anything is going to look dimmer as a DRL because the voltage output is so low.
The voltage on the DRL is low.The stock bulbs are low wattage and does not need as much power to light up,but if your using bulbs like Nokya,luminics,etc. the bulb needs more power. Try turning your high beam on and you'll see a difference.
because the blue would not turn out like the way it looks right now with stockies.
also did not want to do blue DRLs since they just look white.
as for the purples, its white with a hint of purple.
Related Threads
12M posts
157.5K members
Since 2005
