Wiring Issue with Pioneer W4400NEX...Help Please - 8th Generation Honda Civic Forum
Old 11-04-2018, 10:54 AM   #1 (permalink)
SMRcalidiv just put it into 1st gear on 8thcivic
iTrader: 0 reviews
Before I get yelled at...I did search, but as it tends to happen I'm exhausted and having a hard time making sense of some of this...so if you can help out, please do...I need it.
OK, so I bought my wife the Pioneer w4400nex, and accompanying wiring kit through Crutchfield. She has a 2006 lx with ( I thought) the standard audio package (she bought the car before we ever met).
I wired up the main harness color for color, and also wired in the brake bypass I purchased through Amazon, with the blue wire of the bypass going to the "Remote" wire of the new deck's harness. I did not wire in the blue wire of the antenna adapter, and it is just hanging there as of now. I noticed an additional harness that wasn't mentioned in the instructions, and I'm not sure what it is. I left it unplugged and the stereo works, receives radio input, but the rear speakers are noticeably louder than the fronts. There is no static or buzzing noise.
Also, the DVD/Video functions with the car parked, NO emergency brake on, and OUT of "Park"...moving under 5mph...which leads me to believe the bypass is working, but the warning comes on over 5mph ish. Could that be a result of the "GPS" wire/receiver that came with the deck? Meaning that if I unplugged it, the bypass would fully function? I'm just curious how it's working to bypass the need for the car having the E-brake pulled, but not "really" working as intended???
Here is the harness in question:
SMRcalidiv is offline
Old 11-06-2018, 04:04 PM   #2 (permalink)
iTrader: 0 reviews
Bump for HUGE pictures lol
SMRcalidiv is offline   Reply With Quote Quick reply to this message
Old 03-28-2019, 06:04 AM   #3 (permalink)
dirtdevil just put it into 1st gear on 8thcivic
iTrader: 0 reviews
I realize this post is 6 months old now, however I have just installed this same headunit with the bypass. Pioneer released a firmware update that once applied, will allow video playback while in motion. With the radio turned on, you will need to turn all sources off then press & hold the lower left corner for approx 10-15 seconds to toggle this "feature" on & off.
dirtdevil is offline   Reply With Quote Quick reply to this message
Old 03-28-2019, 09:28 AM   #4 (permalink)
iTrader: 0 reviews
Thank you for responding. I JUST did the update like 4 days ago, before a small road trip where I actually needed the GPS and video working. The update worked perfectly.
I was reminded however that the other harness issue never was resolved. Does anyone about that other harness in the pics? It's just dangling there now...
Old 03-28-2019, 04:58 PM   #5 (permalink)
iTrader: 0 reviews
The blue wire on the antenna needs to go to the blue remote turn on wire of the pioneer harness. I'm not sure what the grey plug you have is for, I had the stock nav unit and went with the iDatalink Maestro harness for my install.
Old 03-28-2019, 05:07 PM   #6 (permalink)
striker_1818's Avatar
Christian
striker_1818 has carbon fibre cupholdersstriker_1818 has carbon fibre cupholdersstriker_1818 has carbon fibre cupholdersstriker_1818 has carbon fibre cupholdersstriker_1818 has carbon fibre cupholdersstriker_1818 has carbon fibre cupholdersstriker_1818 has carbon fibre cupholdersstriker_1818 has carbon fibre cupholdersstriker_1818 has carbon fibre cupholdersstriker_1818 has carbon fibre cupholdersstriker_1818 has carbon fibre cupholders
iTrader: 19 reviews
What you are holding looks to be the 20pin harness(for steering wheel control Audio)
And this is how your wiring should look:
striker_1818 is offline   Reply With Quote Quick reply to this message
Old 03-28-2019, 05:09 PM   #7 (permalink)
Christian
iTrader: 19 reviews
PS. You don't need to connect the antenna to the "remote turn on" as it's not a powered antenna unless your car came with a amp.
Sedan DX, LX, DX and Coupe DX, LX do not come with an amp.
For reference, go to my install. We both have a pioneer unit. However, yours is a navigation unit(I think?).
https://www.8thcivic.com/forums/i-c-...nt-budget.html
Old 04-02-2019, 11:09 AM   #8 (permalink)
iTrader: 0 reviews
Thanks for the input guys.
Her car does not have steering wheel controls...so that's not a concern. Also, the radio comes in fine, so that blue wire not being connected isn't causing any issues.
It is probably a result of aftermarket speakers, and perhaps ohms, but I thought her front speakers sounded "quiet" compared to the rears. I wasn't sure if there were tweeters somewhere that didn't get hooked up, or an amp, or something.
It would appear that having that harness unconnected isn't causing any issues...but it just feels weird to know it's just dangling there. OCD issues...
Old 04-04-2019, 12:26 AM   #9 (permalink)
Christian
iTrader: 19 reviews
2006 civic LX do not have tweeters.
Aftermarket speakers should sound just fine. Play around with the deck and also adjust the listening position under settings. But yeah that plug is better to be left alone.
Old 04-04-2019, 02:55 PM   #10 (permalink)
iTrader: 0 reviews
Thanks, and that works for me...less work!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
You may post new threads
You may post replies
Is Honda aware of VINs of engine block issue? NKaufman Mechanical Problems & Technical Chat 10 01-15-2018 12:28 AM
07 Civic intermittent Air Conditioning compressor issue. Ambient temperature related. pjw73nh Mechanical Problems & Technical Chat 0 05-18-2017 10:54 AM
Wiring harness for replacing premium audio system? stugatzo I.C.E., Electrical, Security, & Navigation 1 10-10-2016 12:39 AM
