E85 = Awesomeness - Page 5 - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Forced Induction And Nitrous
Old 10-25-2010, 01:54 AM   #81 (permalink)
Kakashi's Avatar
Avan
Kakashi runs yellow lights with gleeKakashi runs yellow lights with gleeKakashi runs yellow lights with gleeKakashi runs yellow lights with gleeKakashi runs yellow lights with gleeKakashi runs yellow lights with gleeKakashi runs yellow lights with gleeKakashi runs yellow lights with gleeKakashi runs yellow lights with gleeKakashi runs yellow lights with gleeKakashi runs yellow lights with glee
iTrader: 1 reviews
That would be great.
Kakashi is offline   Reply With Quote Quick reply to this message
Old 10-25-2010, 06:08 AM   #82 (permalink)
Bboy_Burst's Avatar
Ku
Bboy_Burst just put it into 1st gear on 8thcivic
iTrader: 7 reviews
Originally Posted by b.r.i.a.n. View Post
the owner of the car doesn't want me to disclose the numbers or post the graph. i had tuned the car with i/h/e and all we did was switch the injectors and switch to e85 and picked up 9 hp O_O
i gained about the same amount of hp also.
Bboy_Burst is offline   Reply With Quote Quick reply to this message
Old 10-25-2010, 06:23 PM   #83 (permalink)
xMut990x's Avatar
xMut990x just put it into 1st gear on 8thcivic
iTrader: 12 reviews
looks like more of a pick up hp wise when the car is f/i
xMut990x is offline   Reply With Quote Quick reply to this message
Old 10-26-2010, 01:21 PM   #84 (permalink)
PainIs4ThaWeak's Avatar
8thCivicRidesPoles
PainIs4ThaWeak just put it into 1st gear on 8thcivic
Garage
iTrader: 21 reviews
Send a message via AIM to PainIs4ThaWeak Send a message via MSN to PainIs4ThaWeak Send a message via Yahoo to PainIs4ThaWeak
Ok well... fellas it looks like we're gonna have to get a Brazilian in on this, lol.
I've talked with AHMC, a local dealer in NC, and even called Honda Brazil in Sau Paulo! And well... considering I'm just a dumb american, and can't speak a lick of spanish, much less portuguese (I had my fingers crossed that they had a button option for "english" - no such luck).
I think I'ma need at least a portuguese speaking individual to find a part # for us.
PainIs4ThaWeak is offline   Reply With Quote Quick reply to this message
Old 10-26-2010, 02:27 PM   #85 (permalink)
Supa Ninja's Avatar
Nick
Supa Ninja just put it into 1st gear on 8thcivic
Garage
iTrader: 16 reviews
Send a message via Yahoo to Supa Ninja
i ran into the language barrier as well when i was researching a flex fuel sender too. babel fish was useless as well. someone fluent in portugese thats familiar with civics would be the key to this mystery. Or figure out a english speaking country that uses ethanol, there has got to be one.
Supa Ninja is offline   Reply With Quote Quick reply to this message
Old 10-26-2010, 02:33 PM   #86 (permalink)
Supa Ninja's Avatar
Nick
Garage
iTrader: 16 reviews
well its not looking too good, your going to need a portugese speaker to solve this Honda offering flex-fuel Civic and Fit... in Brazil only — Autoblog Green
Old 10-26-2010, 03:25 PM   #87 (permalink)
8thCivicRidesPoles
Garage
iTrader: 21 reviews
^ yea I knew about that.
Already PM-ed at least 3 assumed-to-be portuguese speakers here. We'll see if they'll lend a hand.
Old 10-26-2010, 04:08 PM   #88 (permalink)
pedroajr's Avatar
Pedro Aguilera
pedroajr just put it into 1st gear on 8thcivic
iTrader: 0 reviews
Ok guys....
I've received a PM from the user "PainIs4ThaWeak".
I'll call a dealer by tomorrow and try to get an answer.
Chears...
pedroajr is offline   Reply With Quote Quick reply to this message
Old 10-26-2010, 04:20 PM   #89 (permalink)
8thCivicRidesPoles
Garage
iTrader: 21 reviews
^ Awesome!
Pedro informed me though that the only 'flex-fuel' civics that accept ethanol are the R18 LXL and LXS trims.
Nick, you have any idea if either of these will work? I mean all the USDM civics use the same part # for the meter (Edit - 17047-SNA-A30), so I would hope that even a non-si meter from a Brazilian model would work as well.
Old 10-26-2010, 04:44 PM   #90 (permalink)
pedroajr's Avatar
Pedro Aguilera
iTrader: 0 reviews
Another thing is consearning me is this:
1-) Did Honda make or send any "flex-fuel" Civic unit to US market?
If the answer is NO, are you guys running with Ethanol in a car developed only to run with petrol?
2-) Or....did Honda make or send any "Pure Ethanol" Civic unit to US market?
Old 10-26-2010, 04:49 PM   #91 (permalink)
8thCivicRidesPoles
Garage
iTrader: 21 reviews
Nope, no ethanol prepped civics have been sold here.
But if the brazilian flex fuel LXL/LXS's meters share the same dimensions as our USDM ones, then we should be able to use them.
Old 10-26-2010, 04:49 PM   #92 (permalink)
Supa Ninja's Avatar
Nick
Garage
iTrader: 16 reviews
there is only one difference with the fuel cages between r18's and Si's, the r18's have higher psi FPRs...everything else is identical. So you'll need a brazilian flex fuel r18 "meter".
pedro- ya we have been using ethanol in petrol setups with modifications to the fuel senders. If we could use a brazilian fuel level sender then we wouldn't have any corrosion issues. Honda only made the flex-fuel civics for the Brazilian market, you guys are the lucky ones. Here in the states E85 is just starting to become abundant and hasn't really caught on yet.
Old 10-26-2010, 05:08 PM   #93 (permalink)
pedroajr's Avatar
Pedro Aguilera
iTrader: 0 reviews
I got it...
Just one thing you should keep in mind.
Ours Flex-Fuel Civics has two gas tanks.
The bigger one is the main one. About 14,5 gal. (for both fuels)
The small one is about 0,13gal (for petrol only)
Why????
The small one we call "Cold weather engine start tank".
When we use 100% ethanol on the main tank, in cold temperatures (cold menas less than 53F), the ethanol has more dificulties to catch on fire and make the engine works.
Therefore, this small tank, inject every single time you turn the ignition on, a bit of petrol, in order to start the engine smoothly.
When the main tank has more than 10% of petrol in the mixture, this mix is good enough to start the engine with no help of the small tank.
The point is that both tanks speak to each other thanks to the Injection Central .
I'm just a little bit worried about: how your cars do not have this small tank and your Injection Central it's not programed to work on flex fuel (and ours, yes...), my fuel sender may not comunicate properly with your injection central.
Think about it and check if my thought is right or wrong.
Nevertheless, sorry for my english. Ain't good as i would like to.
Old 10-26-2010, 05:25 PM   #94 (permalink)
Supa Ninja's Avatar
Nick
Garage
iTrader: 16 reviews
we only have E85 available at the pumps and in the winter time they mix more petrol in it for hard starting issues. These guys will just have to pay attention and pump a gallon of gas in with the ethanol at fill up if they are in a cold climate and have cold start issues.
Old 10-27-2010, 09:02 AM   #95 (permalink)
pedroajr's Avatar
Pedro Aguilera
iTrader: 0 reviews
Guys...
My fears became truth...
This device do not works with Petrol Civics. Only those already Flex.
Nevertheless, if you want to take a risk, there is the part numbers:
Number Bosch: 1.587.410.742
Number Honda: F 000 TE1 12M -7H1 / 17047SNZ 0000
In time: the cost for it in Brazil is about US$40,00
In time 2: here we have some pictures of it
Hope it helps!!!
Needing anything else, just call me
Old 10-27-2010, 09:58 AM   #96 (permalink)
8thCivicRidesPoles
Garage
iTrader: 21 reviews
Thanks alot Pedro!
Nick - Here it is: http://www.bosch.com.br/br/autopecas...Dvel_Bosch.pdf
Listed in that PDF as "F000 TE1 12M"
(Can't see if this is just the same picture that Pedro posted - as I can't see pics here at work)
But that's obviously a little different that what I remember ours looking like on the Si's.
Old 10-27-2010, 10:11 AM   #97 (permalink)
mitsukaiSI is the 8thcivic ninja warriormitsukaiSI is the 8thcivic ninja warriormitsukaiSI is the 8thcivic ninja warriormitsukaiSI is the 8thcivic ninja warriormitsukaiSI is the 8thcivic ninja warriormitsukaiSI is the 8thcivic ninja warriormitsukaiSI is the 8thcivic ninja warriormitsukaiSI is the 8thcivic ninja warriormitsukaiSI is the 8thcivic ninja warriormitsukaiSI is the 8thcivic ninja warriormitsukaiSI is the 8thcivic ninja warrior
iTrader: 1 reviews
Send a message via AIM to mitsukaiSI
That does look quite a bit different ... It appears that all they did was enclose the circuit board with the pick up in an encasing to seal it from coming in contact with the fuel in the tank.
mitsukaiSI is offline   Reply With Quote Quick reply to this message
Old 10-27-2010, 10:30 AM   #98 (permalink)
Stephen
w00t692 just put it into 1st gear on 8thcivic
iTrader: 5 reviews
Sounds like someone should just dunk their fuel senders in something hehe.
w00t692 is offline   Reply With Quote Quick reply to this message
Old 10-27-2010, 10:38 AM   #99 (permalink)
8thCivicRidesPoles
Garage
iTrader: 21 reviews
Exactly what I thought.
But what I still can't definitively determinie is whether fuel acutally enters the plastic encasing. I mean there is two fittings at the top of the unit that LOOKS like fuel could enter there if not capped off or connected to ______ (something)? But if in fact the fuel does enter that casing, what I'd really like to see is the actual meter, in hopes that its at least CLOSE to the same dimensions as our meters.
I'll sit around an wait to see what those smarter than myself think.
Old 10-27-2010, 11:34 AM   #100 (permalink)
iTrader: 1 reviews
I would imagine that it may be a one way valve to allow fuel or air to escape the casing I can't imagine they would waste te energy/money to encase the sender but allow fuel to enter itentionally... Seems like it would defeat the purpose BUT obviously I can't say definitively as I havnt looked at it up close
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
You may post new threads
You may post replies
LinkBack to this Thread: https://www.8thcivic.com/forums/forced-induction-nitrous/230698-e85-awesomeness.html
E85 Causing Sending Unit 2 Go Bad?? - jdmSOUTH This thread Refback 08-03-2011 12:33 PM
ImTheVoiceOfGod's TWFA5 of awesomeness. (So many pictures, it will break your eyes!) ImTheVoiceOfGod Car Builds 305 10-04-2010 09:50 PM
PURE AWESOMENESS: Girl pays to ride in M3 BMW promo vid habitat Garage 7 10-27-2009 01:10 PM
High-resolution Formula 1 awesomeness RWatters Garage 2 10-20-2009 06:35 PM
Awesomeness or Riced-Out Phone?? string3599 Water Cooler 22 02-23-2008 04:09 PM
