E85 = Awesomeness - Page 11 - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Forced Induction And Nitrous
Old 03-31-2011, 03:01 AM   #201 (permalink)
fg2onspray just put it into 1st gear on 8thcivic
iTrader: 0 reviews
holy sh!t
fg2onspray is offline   Reply With Quote Quick reply to this message
Old 03-31-2011, 06:27 AM   #202 (permalink)
Supa Ninja's Avatar
Nick
Supa Ninja just put it into 1st gear on 8thcivic
Garage
iTrader: 16 reviews
Send a message via Yahoo to Supa Ninja
Originally Posted by VitViper View Post
You guys tried putting epoxy around the connections that wear out?
there is one connector that corrodes(that diy i made you just solder the wire directly to the board), but the actual board corrodes on the resistor traces, i think a expoy coating on the board might fix that but its just a theory right now.
bboy- maybe since neither of us were using checkvalves on the EVAP, if it was humid out then the moisture could have gotten "blown" into the fuel tank. thats another theory i have.
Supa Ninja is offline   Reply With Quote Quick reply to this message
Old 03-31-2011, 05:04 PM   #203 (permalink)
VitTuned 4tw
VitViper's Avatar
Location: Tuning Ignition On The Street For Years :umadbro:
VitViper just put it into 1st gear on 8thcivic
iTrader: 15 reviews
Send a message via AIM to VitViper Send a message via MSN to VitViper
Reason I ask is cause a little birdie told me they have no problems with the sender and ethanol, and mentioned something about epoxy...
VitViper is offline   Reply With Quote Quick reply to this message
Old 03-31-2011, 07:08 PM   #204 (permalink)
PainIs4ThaWeak's Avatar
8thCivicRidesPoles
PainIs4ThaWeak just put it into 1st gear on 8thcivic
Garage
iTrader: 21 reviews
Send a message via AIM to PainIs4ThaWeak Send a message via MSN to PainIs4ThaWeak Send a message via Yahoo to PainIs4ThaWeak
I was under the impression that you'd need to epoxy the entire range of electrical contact "ticks" on the meter itself to truly e-proof it?
So, am I hearing this right, that really the only piece that needs epoxy are the contact points for the black and yellow wires?
(I really need to break out that S. American fuel meter )
PainIs4ThaWeak is offline   Reply With Quote Quick reply to this message
Old 03-31-2011, 08:23 PM   #205 (permalink)
Bboy_Burst's Avatar
Ku
Bboy_Burst just put it into 1st gear on 8thcivic
iTrader: 7 reviews
this past weekend, i was clearing out my trunk and i notice that there were liquid in the area where the spare tire is. it seems like the e85 leaked out? the tool that screws down and hold the spare in place was corroded and i had to break it off.
i will see if i can take a picture of it tonight.
Bboy_Burst is offline   Reply With Quote Quick reply to this message
Old 03-31-2011, 08:24 PM   #206 (permalink)
8thCivicRidesPoles
Garage
iTrader: 21 reviews
wow... odd...
Old 03-31-2011, 09:31 PM   #207 (permalink)
Supa Ninja's Avatar
Nick
Garage
iTrader: 16 reviews
thats weird.
Old 03-31-2011, 10:04 PM   #208 (permalink)
mix
OG VIP Member
mix's Avatar
Chris
mix just put it into 1st gear on 8thcivic
iTrader: 1 reviews
Send a message via AIM to mix Send a message via MSN to mix Send a message via Yahoo to mix
Maybe just normal water, moisture and it just rusted. I am pretty sure you would of smelt gas in your car while driving it around if it was leaking that bad.
By the way you want to check your window seals, and the vent thats close to the bumper area, and maybe have to reseal perimeter of that plastic piece with black silicon.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Houston Peeps click here >>>
For Sale:
mix is offline   Reply With Quote Quick reply to this message
Old 03-31-2011, 10:28 PM   #209 (permalink)
Supa Ninja's Avatar
Nick
Garage
iTrader: 16 reviews
my trunk is leaking too. dude if it is e85 it will smell like a wine-o has been living in there for a month and ethanol evaporates really quick so if it is e85 then its from a fresh leak and i have no idea how it could get into your spare tire well.
Old 03-31-2011, 11:09 PM   #210 (permalink)
Bboy_Burst's Avatar
Ku
iTrader: 7 reviews
took some picture. it looks like the thread for the spare tool is corroded? i wipe down all the liquid, but before i did, there was a puddle in that area.
Old 04-01-2011, 01:02 AM   #211 (permalink)
Supa Ninja's Avatar
Nick
Garage
iTrader: 16 reviews
Make sure your cage is screwed all the way tight and your EVAP is plugged all the way on, check your fuel line too.
Old 04-06-2011, 01:54 AM   #212 (permalink)
Jeremy
Zigg just put it into 1st gear on 8thcivic
iTrader: 0 reviews
Send a message via AIM to Zigg
Eeew... this thread has made me sad.
I used E85 for about a month last summer to work on proper tuning with it, and my fuel gauge is one bar down, and upon the tank getting to the 2-3 bar range, the level does "vary" back and forth, which has gotten annoying. Frankly, it's unfortunate, but keep your tank filled more than halfway and you'll never need a worry.
Zigg is offline   Reply With Quote Quick reply to this message
Old 04-07-2011, 07:50 AM   #213 (permalink)
Guess
bouncer07 just put it into 1st gear on 8thcivic
iTrader: 2 reviews
Been following this thread - good information on E85 on the pros and cons but the cons of destroying something the car needs to run isn't worth the extra mile for me. If this happens to get a whole new fuel line of accesories for repairs, I'm sticking with regular premium 93.
bouncer07 is offline   Reply With Quote Quick reply to this message
Old 04-07-2011, 06:07 PM   #214 (permalink)
Bboy_Burst's Avatar
Ku
iTrader: 7 reviews
ok, so my fuel gauge doesn't read at all anymore. time for a new meter!
Old 04-07-2011, 08:36 PM   #215 (permalink)
8thCivicRidesPoles
Garage
iTrader: 21 reviews
yup yup
Old 04-07-2011, 09:14 PM   #216 (permalink)
1SIKCIV's Avatar
kyle
1SIKCIV just put it into 1st gear on 8thcivic
iTrader: 0 reviews
i filled up on E the other day and got tuned, stock rail, IC1000, crushed fpr, walbro 255, and hit 18psi for my max, well the last day finishing up the street tune, i was doin the last pull of the night, and lost my license over it lol but E made it a completly Diffrent Monster. i love it
1SIKCIV is offline   Reply With Quote Quick reply to this message
Old 04-07-2011, 09:39 PM   #217 (permalink)
Supa Ninja's Avatar
Nick
Garage
iTrader: 16 reviews
that sucks about your liscence
With a turbo, E makes it into a monster! Keep us updated
bboy- that sucks dude. At least the stocker lasted a good amount of time.
Old 04-08-2011, 04:33 AM   #218 (permalink)
Bboy_Burst's Avatar
Ku
iTrader: 7 reviews
I've been using E85 for 9 months and the fuel sender finally gave out. I still don't regret it though
btw, i took the fuel assembly out, but couldn't really tell what was corroded. what exactly do i need to replace? when you buy the new meter, does it come with the black/yellow wire only? what else does it come with? would it be better to replace the whole cage?
Old 04-08-2011, 09:35 AM   #219 (permalink)
smokeyBLUEdyno just put it into 1st gear on 8thcivic
iTrader: 0 reviews
I was thinking that epoxy would work similar to when they dip circuit boards for water proofing.
What kind of cost is involved for the new meter? Thats definately something to consider if in fact it does fail in about a years time. ? for people running e85.
Have you ever let your car sit for more tan a few weeks and have problems? I have always been very interested in running e85 but its not my dd so might not be a good idea...Could heet be a good alternative?
Also I talked ith a local tuner and he said the variance in the ethanol % varies alot even during specific seasons and recommends meters to measure that...problem is that the system is very expensive for al the components. Maybe the quality suffers n my region??(Ohio)
smokeyBLUEdyno is offline   Reply With Quote Quick reply to this message
Old 04-08-2011, 09:36 AM   #220 (permalink)
8thCivicRidesPoles
Garage
iTrader: 21 reviews
No need to replace the whole cage.
I don't believe the meters come with leads of any kind (don't believe they're neccessary), but its been a second since I've taken my fuel cage out and looked at everything, so I could be wrong about the leads.
Worse comes to worst, you'd just need to resolder the black and yellow leads to the meter.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
You may post new threads
You may post replies
LinkBack to this Thread: https://www.8thcivic.com/forums/forced-induction-nitrous/230698-e85-awesomeness.html
E85 Causing Sending Unit 2 Go Bad?? - jdmSOUTH This thread Refback 08-03-2011 12:33 PM
ImTheVoiceOfGod's TWFA5 of awesomeness. (So many pictures, it will break your eyes!) ImTheVoiceOfGod Car Builds 305 10-04-2010 09:50 PM
PURE AWESOMENESS: Girl pays to ride in M3 BMW promo vid habitat Garage 7 10-27-2009 01:10 PM
High-resolution Formula 1 awesomeness RWatters Garage 2 10-20-2009 06:35 PM
Awesomeness or Riced-Out Phone?? string3599 Water Cooler 22 02-23-2008 04:09 PM
