Kraftwerks Supercharger & Hondata Tune - Car bucks at 5K RPM's in 1st and 2nd Gear - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Vendors > Evans Tuning
Old 01-10-2019, 11:29 AM   #1 (permalink)
kingRAZrock's Avatar
Ronnie
kingRAZrock just put it into 1st gear on 8thcivic
Garage
iTrader: 0 reviews
My car bucks at 5K+ RPMs in 1st and 2nd gear. Third through six pulls hard with no problems in the same range. My 2006 civic SI has been dyno tuned at 430.9 HP to wheels. It's almost as if a rev limiter has been applied to the tune. Not certain what the problem is. Please help! I just had the top of the engine rebuilt due to failure and was ass raped by a mechanic. The starter motor, knock sensor, camshaft solenoid adjuster was also replaced recently.
Current mods are as follows:
Kraftwerks Supercharger Kit
Hondata Flash Pro Engine Management System
Hondata Thermal Heatshield Intake Gasket
Brian Crower Stage 2 Camshafts N/A / F/I
Brian Crower Dual Springs, Steel Retainers, Steel Seats
Brian Crower Keeper Locks
Drag Cartel Variable Exhaust Cam Gear
Full Race Exhaust
Skunk 2 Alpha Race Header
Port & Polished Cylinder Head
Skunk 2 Type R Shift Nob
Redline Black Perforated Leather Shift Boot, Double White Racing
Stitching
GrillCraft Front & Lower Grill
M3 Style Mirrors with LED Lighting
Koni Yellow Suspension
Spec R Springs
SPC Front Camber Bolts
SPC Rear Camber Arms
Progress 24 mm Rear Sway Bar
HFP Short Throw Shifter
HFP Body Kit
HFP 18 Inch Rims
General G-Max 215 40 ZR 18 89 W Tires
EBC Performance Brake System Cross Drilled & Slotted Rotors
EBC Yellowstuff Brake Pads - Premium Street, Performance + Race
Calhoun Red Powder Coated Front & Rear Calipers
After Market Pioneer Navigation, CD/DVD Player, Radio, I-Pod
JL Audio Speakers, Tweeters, JL Audio 12 Inch Sub Woofers, 2 JL Audio
Amplifiers, Power Pack
The tune on the motor was completed by JK Motorsports in Milford, Ct by Jerry. I upgraded from a DC Sports short header to Skunk 2 Alpha Series and replaced a 2.5" Vibrant with a 3" Full Race exhaust. Shortly after the install, the engine failed as the timing tensioner blew apart and damaged the valves. I had the top of the engine completely rebuilt and tuned. The check engine light came on in the first 30 miles and produced the following codes: PO133 - 02 Senser Circuit Slow Response Bank 1 Sensor 1, PO420 - Catalyst System Efficiency Below Threshold Bank 1 and P0171 - System Too Lean Bank 1. He must have forgotten to tune out the catalytic converter and fuel timing was off causing the car to run lean. Once the check engine light came on I didn't drive it over 5000 RPMS in any gear. I brought it back to him three days later and he reconfigured the fuel mixture and tuned out the cat.
The car jerks and or bucks in 1st and 2nd gear at 5000 RPMS but when you mash on it zips through both 1st and 2nd gear skipping from 5000 to redline immediately. Do you think it may have something to do with the tune? I really don't want to go back to this guy in Milford and am considering Evans Tuning in PA. If the problem isn't with the tune a retune would be a waste of time and money. What are your thoughts?
Hooked up an OBD reader this morning and there is a stored code P2A00 - 02 Sensor Circuit Range Performance Bank 1 Sensor 1. The check engine light did not come on. Does anyone have any thoughts on my looming problems with this vehicle? Is the tune the issue based on your experiences or the 02 sensors? If I change the 02 sensors do you believe the jerking and bucking will stop in 1st and 2nd gear after 5,000 RPMS? The Kraftwerk's belt is also starting to fray and have ordered a replacement. Going to bring it to a local mechanic to have it swapped out and troubleshoot the code. Any help would be appreciated. I am trying to get the car running right. Please help!
I brought the car in today and will keep you posted.
kingRAZrock is offline
Old 01-10-2019, 06:52 PM   #2 (permalink)
Ronnie
Garage
iTrader: 0 reviews
Changing the 02 upstream sensors didn't correct the problem.
kingRAZrock is offline   Reply With Quote Quick reply to this message
Old 01-17-2019, 09:11 AM   #3 (permalink)
Ronnie
Garage
iTrader: 0 reviews
The injector size was reduced from 900 to 800 on the Hondata Flashpro Management and the problem was rectified by my tuner Jerry at JK Motorsports in Milford, CT. The Kraftwerk's Kit runs Grams injectors 1000 and the tuner suggested they were failing.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
You may post new threads
You may post replies
Kraftwerks Supercharger & Hondata Tune - Car bucks at 5K RPM's in 1st and 2nd Gear kingRAZrock ECU Tuning Information 9 01-19-2019 06:07 PM
Kraftwerks Supercharger & Hondata Tune - Car bucks at 5K RPM's in 1st and 2nd Gear kingRAZrock Civic SI 2 01-17-2019 09:11 AM
Kraftwerks Supercharger & Hondata Tune - Car bucks at 5K RPM's in 1st and 2nd Gear kingRAZrock Supercharging 4 01-17-2019 09:10 AM
Kraftwerks Supercharger & Hondata Tune - Car bucks at 5K RPM's in 1st and 2nd Gear kingRAZrock Mechanical Problems & Technical Chat 1 01-16-2019 04:59 AM
Kraftwerks Supercharger & Hondata Tune - Car bucks at 5K RPM's in 1st and 2nd Gear kingRAZrock Hondata 1 01-10-2019 06:50 PM
