Smaller diameter power steering pulley (R18) - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Bolt-Ons And All-Motor > Engine Swaps, Mounts, Pulleys
Old 09-28-2016, 06:47 AM   #1 (permalink)
2poler's Avatar
Joe
2poler just put it into 1st gear on 8thcivic
iTrader: 0 reviews
Looking for info on swapping the current R18 power steering pulley with one that is a smaller diameter. I need a few mm of clearance for the axle on the passenger side. Chassis is a bagged 08 coupe with a 3ish inch notch for axle on the passenger side and a 1-inch notch on the driver's side. drivers side lays subframe but on the driver's side I had to stop the notch or the axle will lay on the pulley when air'd out. I should only need a few mm to clear. I know the JDM motor is no power steering so it has a different smaller pulley but looks lite is is smooth and not grooved for the belt. Looking for an aftermarket option but am only seeing the # piece options and nothing for the power steering, Do the K/B/D/H series power steering pullies fit the pump? I have no issues changing the belt to a different size but have run into a wall when looking for options.
pic is current clearance. If I notch any more the axle will ay on the belt/pulley stapping me from starting the engine when lay'd out.
IMG_20160314_174334 by anasia13, on Flickr
2poler is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
You may post new threads
You may post replies
