I threw a piston in my '07 Honda Civic EX coupe. Don't know much about engine swaps, so I'm looking for advice in regards to the:
- types of engines I can put in my car
- prices
Basically, I'm just looking for the most logically sound decisions for swaps. I wouldn't mind a K20A swap, but I don't know much about it. Any ideas, insight, or additional information would be very helpful and much appreciated.
like ika said above the cheapest and easiest thing to do is swap in another r18, but iff your looking for something with more power then I'd say go k24
I don't no if this will help but yesterday I took my 07 civic with 240,000 km to Honda about coolant in the engine block. They confirmed a crack in the lower engine unit and said Honda will pay for everything, car will be ready for Monday.
that is because there is a bulletin about that. some of the honda blocks are showing up porice, leaking coolant out of them. in the above case. honda wouldnt do anything because it went bang.
You could swap a k20 but as previously mentioned, it wont be cost effective. A good k20 with trans, ecu, and harness will run you 3000+.
Then you need supporting mods, fuel set up, exhaust, axels, so on and so forth.
Your best bet would be to contact a junker and see if they have any used r18's that have low milage, and just swap over your transmission and harness.
I was made aware of the technical bulletin from reading on this board.So if a Honda tech finds a crack in the block of any civic with an R18 engine between the years 06-09, Honda will extend the warranty to 8 years on your civic. I found coolant in the oil pan with 239,000 km on the engine. Took it to Honda asked to find the leak, they called me the same day to say I'm getting a new lower block at no cost to me.
Related Threads
12M posts
157.5K members
Since 2005
