(wire colors that i list are for the 06 Si, coupe. Other cars wire colors may vary. "Kkim", says that the 07 sedans wire is purple)
Choose a place for your radar detector.... i chose up high so it would be difficult for thieves to see and it would not interfere with my windshield deflector. (yes i know that i lose rear, laser coverage but i like the position i chose and i dont really care about rear coverage for laser)
for a clean install, roll all your wires up so they will be the correct length.
Pop off plastic covers on the dome lights and unscrew the two nuts on the inside. Pull out the dome light and shove all your wires up there.
Tap in to the dark green wire 4 pins from the edge of this harness. This is the positive wire
Put the dome light back and make sure to run the ground wire through for the ground on the screw.
Here it is... Its all working....
