Go Back   8th Generation Honda Civic Forum > The Auto Mall - Marketplace - Sponsored Posting > Z1 Performance Inc
Old 04-04-2008, 05:32 PM   #21 (permalink)
8thcivic Sponsor
Z1 Performance's Avatar
yes, fully adjustable
Jonathan - www.z1auto.com - 631-863-3820
GT-SPEC FENDER BRACE PRE-ORDER!
http://www.8thcivic.com/forums/z1-pe...-preorder.html
Check out our BLOG for:
-Customer rides
-New products
-Original articles
Z1 Performance is online now   Reply With Quote
Old 04-07-2008, 01:27 PM   #22 (permalink)
Sambos | We the BEST!
infinite0216's Avatar
Andy
Just ordered them! Can't wait!!
infinite0216 is offline   Reply With Quote
Old 04-07-2008, 01:37 PM   #23 (permalink)
When you install them remember to use the A hole in the rear. I wanted -.9 degrees of camber in the rear so I thought for more negative camber you go with the b hole. The b hole gives you too much negative camber. You will know what i'm talking about when you see the install instructions Good luck and enjoy.
zumzumzoom is offline   Reply With Quote
Old 04-07-2008, 01:45 PM   #24 (permalink)
BigMoney8481's Avatar
Randy
Originally Posted by zumzumzoom View Post
...use the A hole in the rear... The b hole gives you too much... You will know what i'm talking about... Good luck and enjoy.
thats funny
BigMoney8481 is offline   Reply With Quote
Old 04-07-2008, 02:03 PM   #25 (permalink)
Andy
Thanks!
Old 04-07-2008, 08:47 PM   #26 (permalink)
8thcivic Sponsor
Originally Posted by infinite0216 View Post
Thanks!
Selling like hotcakes on the front/rear combo! I can't believe we waited this long to install the kit :)
Not does the car handle better thanks to the proper alignment, but the car looks SO much better with all of that negative camber out of the rear!!
Here are our alignment specs if anyone is interested...this is just a very slightly more aggressive alignment than stock. You can achieve even more negative camber up front with 2 front SPC bolts per side (we only used 1 per side). Then you can dial in nearly -1.5 degrees of negative camber up front and -1.0 out back to completely change the factory balance of the car that will REALLY compliment a Progress rear sway bar.
Front
Camber -0.5
Toe 0.00
Rear
Camber -0.9
Toe 0.00
-Customer rides
-New products
-Original articles
SPC Camber Kit Rear Civic_Si CorSport 39 10-02-2008 06:48 PM
How difficult to install camber adjustment kits? RedSIinPA Suspension and Brakes 1 10-15-2006 12:21 AM
SPC Camber part numbers? hoanger Suspension and Brakes 2 09-30-2006 10:53 AM
spc camber kit help bodydraggin Suspension and Brakes 14 07-25-2006 06:00 PM
spc camber kit Marin Suspension and Brakes 2 07-24-2006 12:53 AM
