Click Here
Old 06-25-2006, 09:53 PM   #1 (permalink)
cmf
Wheel fitment issues
I have read through the threads stickied above, but seem to still be lost as to whether or not the wheels I am looking at will work without fitment issues.
I want to eventually lower the car on coilovers, so I know that is an important factor as well, but I have read that I need to ensure proper clearance from the suspension components as well.
I am looking to run a set of 18X8 wheels. Should I get them in a +37 or +45 offset for proper clearance without rubbing while lowered? Planning to use 225/40 series tires.
Any help would be appreciated.
cmf is offline   Reply With Quote
Old 06-25-2006, 11:42 PM   #2 (permalink)
+45 should clear
Tate is offline   Reply With Quote
Old 06-26-2006, 01:16 AM   #3 (permalink)
b-man's Avatar
If you can, go for 48mm offset with 18X8" wheels. 45mm may be okay though, but 48mm will work better.
Tucking them in just a few more milimeters might make all the difference.
I have 18X8" 48mm offset wheels on my sedan with 225/40s. I did a lot of measuring inside the wheelwells and made drawings (like a blueprint) of various wheels with different widths and offsets to determine what would fit best.
If you can only get the wheels you want in 45mm it might be better to use a 215/40-18 tire for a little more clearance.
b-man is offline   Reply With Quote
SI wheel question 6spdChick Mechanical Problems & Technical Chat 15 10-12-2006 01:25 PM
Coupe/Si Steering Wheel in a Sedan? iVTEC Inside and Out 9 06-19-2006 08:06 PM
EX and Si only - inner wheel well flap? NF15B Mechanical Problems & Technical Chat 1 05-29-2006 09:49 PM
Wheel Alignment after strut removal Lek Mechanical Problems & Technical Chat 5 05-22-2006 03:39 AM
Wheel fitment... Now maybe a problem DumbasSi Wheel And Tire Upgrades 26 04-27-2006 06:10 PM
