Click Here
Old 05-14-2008, 02:39 PM   #1 (permalink)
8thcivic Sponsor
Spencer@tirerack's Avatar
VOLK TE 37 18" fitment on SI
Hey guys!
I have been asked about this wheel allot lately, and there has been a bit of a buzz on the fitment on the 18" setup. Our techs noticed, and confirmed that the gasline is slighly moved from the coup model to the sedan, adding on top of that the open-air cusioning then the thick plastic shell surrounding it from impact damage. This causes some wheels, including the VOLK models, to not fit properly and possibly cause rubbing issues. People have done mods to their vehicle in order to make this work (as you can do with about anything if determined enough), but I wanted to make everyone aware of the issue there!
FYI, it is the passenger rear well which has the protrusion
Let me know if you have questions!
Spencer@tirerack.com 1-877-522-8473 x690
*Remember to reference my name on Tirerack online orders*
Use the link below to support the forum!
http://www.tirerack.com/winter/index.jsp
Spencer@tirerack is offline
Old 05-14-2008, 02:43 PM   #2 (permalink)
deuce0880's Avatar
Alan
i have the 18" Volk TE37's on my FA5 and they fit perfect even on my Skunk2 Pro-S Coilover drop. I have no issues with rubbing at all!
deuce0880 is offline
Old 05-14-2008, 03:03 PM   #3 (permalink)
JeShUa's Avatar
Keepin` it Phresh
What fitment are you selling 8th gens?
JeShUa is offline
Old 05-14-2008, 03:17 PM   #4 (permalink)
deuce0880's Avatar
Alan
They are only selling 17" inch Volk's, if you want to get the 18"'s you have to go through Spencer or someone on the phone...
Old 05-14-2008, 03:31 PM   #5 (permalink)
8thcivic Sponsor
The ones listed by Volk for the vehicle are the specs:
18X7.5 5-114 ET48
It was initially listed for both the coup and sedan model, but when we got complaints about the rubbing issues on the sedans, we looked into it. The problem is the gas line being moved. This is primarily for the TE37 model. Mackin knows about this as well...no real solution as of yet. Good point above tho, as not everyone experienced this rubbing...its kindof hit or miss for whatever reason.
Old 05-14-2008, 03:34 PM   #6 (permalink)
8thcivic Sponsor
And also, not just someone, if you call, make sure you talk to me. 800-428-8355 x690. nothing like my honda guys not calling the honda guy at TireRack! breaks my heart....
Call also if you have questions about it...I'll run you through about the best I can!
Old 05-14-2008, 04:40 PM   #7 (permalink)
One Goal, One Vision, Win
jrotax101's Avatar
Robert
18X7.5 5-114 ET48
Why would the volks rub, but the mugen GP's don't? They are the same size and same offset.
People say BMW drivers are assholes. Maybe that's why i want one...
jrotax101 is offline
Old 05-14-2008, 08:16 PM   #8 (permalink)
deuce0880's Avatar
Alan
i believe its mostly for the coupe's vs. the sedan because of the different body style. Although i'm not positive, i think that my be a factor into this as well. Not too sure though...
Old 05-14-2008, 08:20 PM   #9 (permalink)
JeShUa's Avatar
Keepin` it Phresh
A lot of things come into factor. I'd run a higher offset though.. but I'm sure theres nothing else close like 18x8+35?
JeShUa is offline
Old 05-14-2008, 08:24 PM   #10 (permalink)
Stylinhonda's Avatar
Stephen
I'm confused. How do you know if yours will rub or not? Just have to wait till you get them and install? I have the 18x7.5 40mm TE37s on order.
Stylinhonda is offline
Old 05-14-2008, 08:43 PM   #11 (permalink)
JeShUa's Avatar
Keepin` it Phresh
You will have no problems.
JeShUa is offline
Old 05-14-2008, 08:44 PM   #12 (permalink)
Stephen
Yah hope not.....I've been waiting for my Mag Blues for a while now, don't want any issues.
Old 05-15-2008, 07:34 AM   #13 (permalink)
just replace the fuel line with a steel braided one...$24 bucks at pepboys...and you can dub the sucka
k3tsurui is offline
Old 05-15-2008, 07:45 AM   #14 (permalink)
SiXXSPD's Avatar
ASM|Si|NAV|HFP|HID|PSB|5ZGN
I believe coupe can accomodate more agressive offset (low offsets like +35 to +38)
On the other side, higher offsets tend to make your wheel go in resulting into hitting you inner suspension. On the back of the sedan, there is a plastic cover that protects the gas line. (Thats where it tend to hit or rub).
I have an 18 x 8.5 with +47 offset (you can imagine how wide it is and have a high offset which makes it go in more, I don't have any issues with inner suspension, no modification, no rolling of fenders whatsoever.
SiXXSPD is offline
Old 06-04-2008, 04:00 PM   #15 (permalink)
csxian's Avatar
I just bought LE37T 18x7.5 ET43. I'm gonna run it on stock suspension and I have sedan. Do I need a spacer or anything to avoid rubbing?
csxian is offline
Old 06-04-2008, 04:10 PM   #16 (permalink)
JeShUa's Avatar
Keepin` it Phresh
Lol, no.
JeShUa is offline
Old 06-04-2008, 04:18 PM   #17 (permalink)
csxian's Avatar
Thanks dude... That's such a relieving news... Ehm, that's also no rubbing issue, right? How many inch drop I can get without using any spacer or aftermarket camber arm?
Do you know what spring will give comfort as well as handling? I don't want anything too bouncy.
csxian is offline
Old 06-04-2008, 04:51 PM   #18 (permalink)
jrotax101's Avatar
Robert
you should use a rear camber arm anyway. Spring's aren't for handling, they are for looks. Read through the suspension forum for more info.
You can lower 2" with some negative camber with no rubbing. It isn't really classified as an aggressive offset, being 2mm from stock.
Old 06-04-2008, 05:38 PM   #19 (permalink)
csxian's Avatar
I know this is a noob question, but what is the camber arm for?
csxian is offline
Old 06-04-2008, 05:40 PM   #20 (permalink)
JeShUa's Avatar
Keepin` it Phresh
Its for adjusting camber.
JeShUa is offline
Where to find Volk Racing TE-37 Decals... Hondahawaii777 Wheel And Tire Upgrades 7 09-19-2007 09:42 AM
volk Magnesium TE-37 GORDATA Wheel And Tire Upgrades 39 06-21-2007 02:16 PM
Volk TE-37 Question Eltrentz Wheel And Tire Upgrades 8 05-30-2007 02:06 PM
