Click Here
Old 04-20-2008, 11:29 AM   #1 (permalink)
Would these tires fit these?
I am looking into getting a set of 5zigen Fn01r-c (bronze) with specs Size: 17x8
PCD: 5x114.3, ET: 43, Weight: 17lbs. and currently have a set of 215/45ZR17 Goodyear Response edge tires on my stock wheels. Would these fit the Fn01r-c? i looked at the specs for the Goodyear tires and it said Rim Width Range: 7-8'' and Meas Rim Width is 7''. and will be doing the hpf suspension down the road. I should have any problems with this setup right?
I figure once the aftermarket set is on, im going to be to lazy and would want to keep them on all year anyways.
SouthJersey06blacksi is offline
Old 04-20-2008, 11:36 AM   #2 (permalink)
02civicsi's Avatar
I am the Juggernaut!!!
They will fit but you should really look into getting some wider tires instead. I'm running the OEM size tire on my 17x8 Traklites but they are waaayyy stretched. I'm debating between 235's or 245's once the shitcelins are done.
02civicsi is offline
Gas Mileage poll: Summer tires vs. All-season tires on the Si DanH_PsyD Civic SI 20 12-13-2007 06:44 PM
