Click Here
Old 03-23-2008, 04:30 PM   #1 (permalink)
does anyone have this problem with the back wheels?
I upgraded to 18inch rims and a 225/40 tires. After i put them on i noticed that the back wheels are bowed inwards. I took the car up to the place where i got an alignment done and they said it is normal and no way to fix it.
They did say tho that my tires will wear quicker on the inside tread.
Anyone else have this problem.
Dan1981 is offline   Reply With Quote
Old 03-23-2008, 04:37 PM   #2 (permalink)
nelsonr31's Avatar
Get a camber kit. That bowing you're describing is negative camber. Are you lowered?
nelsonr31 is offline   Reply With Quote
Old 03-23-2008, 04:49 PM   #3 (permalink)
Dillan07's Avatar
Camber kit ftw
Dillan07 is offline   Reply With Quote
Old 03-23-2008, 04:55 PM   #4 (permalink)
no my car is not lowered......can u use the camber kit without lowering the car?
I never lowered any car i had yet so i dont know much about that.
Also.....it wont hurt anything if I chose not to get the kit?
Old 03-23-2008, 09:15 PM   #5 (permalink)
nelsonr31's Avatar
You can deffinitly use a camber kit without lowering the car but it's totally up to you, it won't do any damage if you choose not to get the kit but just like the mechanic said you'll wear the inside thread quicker on the rear tires. Just rotate your tires a little more often if you don't want to get a camber kit, that should prolong your tires.
Old 03-23-2008, 09:15 PM   #6 (permalink)
Survivor's Avatar
Even a new stock Si will wear the inside treads of the rear 17" tires. I read somewhere in another post here, that Honda is correcting this on the non-Si models. Meaning less camber and less handling ability compared to the Si with its inner rear tire premature wear. Oh well!
Survivor is offline   Reply With Quote
Old 03-23-2008, 09:16 PM   #7 (permalink)
nelsonr31's Avatar
Honda has a new rear upper control arm to correct this camber problem.
Old 03-26-2008, 04:14 PM   #8 (permalink)
I have the same problem on my FBP Si w/ 225/40/18's on 18x7.5's w/42mm offset and stock suspension. I'm glad I'm not the only one.
Aaron06Si is offline   Reply With Quote
Old 03-26-2008, 04:28 PM   #9 (permalink)
Go On Girl...
pgFA's Avatar
Pao
For, SI's, the stock rear camber is "suppose" to be -0.5 or -0.45 I believe (From the owners manual. Not sure which one). When I had my first alignment, I was at -1.5. I guess its pretty normal that the SI has that much rear negative camber. And that -1.5 is still with in "factory spec". And yes, they can not adjust the camber with the stock arm. You need the rear camber arm to correct the camber. BTW, I have FA5. I don't know if its the same for FG2.
pgFA is offline   Reply With Quote
Old 03-26-2008, 04:33 PM   #10 (permalink)
thedamaja's Avatar
Respect my authoritah!
Since when is some camber a problem?
The Si is spec'ed for some rear camber and toe in. Going to a wider rear just makes it more visible.
I'm not sure how much adjustability (if any) is built in but, you could always get it re-aligned to 0. This will affect your handling though.
Stock Alignment 07 Sedan from the manual
Front
Toe-in 0
Camber 0
Caster 7°24’
Rear
Toe-in 0.08in(2.0mm)
Camber -1°30’
thedamaja is offline   Reply With Quote
Old 03-27-2008, 03:28 PM   #11 (permalink)
Front
Toe-in 0
Camber 0
Caster 7°24’
Rear
Camber -1°30’
As far as I know the camber is STILL not adjustable. My right rear came out at -2.3 deg.
Old 03-27-2008, 04:02 PM   #12 (permalink)
thedamaja's Avatar
I figured as much, guess you'd need to throw down some bucks for an alignment kit. They seem to be extra expensive for this car.
Old 03-27-2008, 10:55 PM   #13 (permalink)
Go On Girl...
pgFA's Avatar
Pao
Yeah. Just look around but on average its around $250 for both front and rear depending on the brand. I got my SPC on sale from one of the sponsors for $210 shipped for both so just keep an eye.
Si has the same problem as the S2000 had a few years back. gibbletz Civic SI 26 09-29-2007 02:31 AM
Back speaker problem. HELP!!!!! lilblaze27 I.C.E., Electrical, Security, & Navigation 8 09-09-2007 09:57 PM
Problem w/ Tein and Large wheels Max2.0 Mechanical Problems & Technical Chat 19 04-27-2007 07:15 PM
Just got my wheels back!! Englishe30 Wheel And Tire Upgrades 13 04-01-2007 11:20 AM
problem with wheels boomber45 Wheel And Tire Upgrades 5 03-14-2006 07:54 PM
