Click Here
Old 06-05-2006, 03:31 PM   #1 (permalink)
OHSiGuy's Avatar
Torquing lugs??
At the risk of sounding stupid (which I do somewhat frequently...on alot of different fronts) I was wondering how many people used a torque wrench when installing their new wheels. I ordered some new wheels for my Si over the weekend from Wheelmax. Their wheel/tire packages come with an installation kit that includes hub centric rings...anyone used these on their cars before??
I've installed alot of spare tires in the past, but never any new, aftermarket ones that are intended to remain on the car. I obviously don't want to screw anything up during the removal of the OEM rims and the install of the new ones. Thanks for any advice.
MODS: Wasn't sure whether to post this in the DIY section or here.
OHSiGuy is offline
Old 06-05-2006, 03:34 PM   #2 (permalink)
Minister of Discord
Janizary's Avatar
Gas thread Nazi
Yes, use the hubcentric rings, if provided.
Additionally, the use of the stock 'rounded' lugs is NOT suggested due to fitment. Conical or tapered lugs are preferred.
Yes, using a torque wrench is recommended. On the Si I believe it is 80# or 85#. Additionally, it is recommended to re-torque your lugs between 30 and 70 miles after installation, particularly on aluminum alloy wheels.
Janizary is offline
Old 06-05-2006, 03:43 PM   #3 (permalink)
Photobucket
Silver8th's Avatar
Also, when you torque them do so in a star pattern.
Silver8th is offline
Old 06-05-2006, 03:46 PM   #4 (permalink)
Acorn!
2fast4u2's Avatar
8thcivic.com member #15
I always use a torque wrench. And Janizary is correct. The torque for the Si is 80#.
2fast4u2 is offline
Old 06-05-2006, 03:58 PM   #5 (permalink)
OHSiGuy's Avatar
Thanks alot guys! The wheelmax install kit comes with lugs. I'll have to go buy a torque wrench. Any suggestions on a good one to buy?
OHSiGuy is offline
Old 06-05-2006, 05:44 PM   #6 (permalink)
Wrathchild's Avatar
Sears has em for 60 bucks...dont need anything special if your just torqueing down your wheels.make sure you have a 19MM socket for it(if the size is the same as the coupe). and untwist it when your done using the wrench you could screw it up leaving it on 80 ftlbs.
http://www.sears.com/sr/javasr/produ...cegjdghldfom.0
Wrathchild is offline
Old 06-05-2006, 09:53 PM   #7 (permalink)
I am not a big fan of Husky tools normally but their 50-250 lb torque wrench
was cheaper and of better quality than the ones I looked at my local Sears. Most Home depot stores carry the Husky tools. I checked Napa too and they had some nice torque wrenches but were double the price of the others mentioned here.
shawn
sbmon is offline
Old 06-06-2006, 07:31 AM   #8 (permalink)
DEEDS's Avatar
aren't all hondas/acuras 80 excpet the Ridgeline and the MDX?
DEEDS is offline
Old 06-06-2006, 01:26 PM   #9 (permalink)
kenchan's Avatar
if you only need to do lugs, you can get a cheepo from www.tirerack.com for like $30. they work just fine, just remember to set it back to less than 10lbs/ft after you're done.
also, remember to re-torque your lugs after you drive 5-10miles. lugs sometimes loosen as they settle onto the wheel.
kenchan is offline
Old 06-06-2006, 01:55 PM   #10 (permalink)
OHSiGuy's Avatar
Thanks for all of the help everyone...good find Kenchan. I'm getting that torque wrench from Tirerack.
OHSiGuy is offline
Will EX lugs work OK w/SI wheels? otsacto Wheel And Tire Upgrades 4 05-04-2006 01:38 AM
Honda Locking Lug Nuts Tennisjon2002 Inside and Out 3 04-20-2006 04:38 PM
