Click Here
Old 03-22-2008, 09:29 AM   #1 (permalink)
Will this size wheel/offset work?
I know there are multiple threads covering this, but I didn't see this particular size/offset covered. Everything I saw went below and above it, so I'm not positive if it will fit.
Size is 18 x8 +46 wheel.
If it will work on a dropped si sedan, what size tire will fit with it?
Busta_Si is offline   Reply With Quote
Old 03-22-2008, 09:37 AM   #2 (permalink)
20strong's Avatar
Marcus
Maybe, a 225/40-18 tire should od the trick. Make sure that you check suspension clearance.
20strong is offline   Reply With Quote
Old 03-22-2008, 09:43 AM   #3 (permalink)
Moderator
Qshooter151's Avatar
Jordan
18x8 45mm offset 225/40-18 (lowered on Eibach Pro Kit with Negative rear camber)
taken from this thread-
Wheel Fitment Recipe - wheel offsets that work
Qshooter151 is offline   Reply With Quote
Old 03-22-2008, 05:22 PM   #4 (permalink)
i saw that the +45 will work, but all they have in the rim is the +46 offset. will that work also? i'm looking at z1auto's package deal of Konig Runaways and Progressive products.
Old 03-22-2008, 05:27 PM   #5 (permalink)
i mean the progress products
Bump - also added prices below with Progress springs and Progress rear sway bar as a package!
17x7 +44, 5-114.3 -18.3 lbs - priced at just $880.00 shipped !!!!
17x7 +40, 5-114.3 - 18.3 lbs - priced at just $880.00 shipped !!!!
17x8 +46, 5-114.3 - 19.2 lbs - priced at just $915.00 shipped !!!!
18x8 +46, 5-114.3 - 21.1 lbs - priced at just $999.99 shipped !!!!
All under $1000.00 for wheels, springs and sway bars!!
Old 03-22-2008, 06:08 PM   #6 (permalink)
Moderator
Jordan
1 millimeter = 0.039 inch which is a tad over 1/32 of an inch. i think you'll be fine.
Getting 18x8 (+33 offset) rims - which tire size??? nastynogales Wheel And Tire Upgrades 9 02-17-2008 02:13 PM
Wheel offset I-JTEC88 Wheel And Tire Upgrades 0 09-27-2007 01:27 AM
17x7.5 40 offset, what size tire? bluetroll Wheel And Tire Upgrades 4 05-29-2006 12:30 PM
stock rim size and offset??? jdmk20z3 Civic SI 1 04-17-2006 01:37 AM
