wheel options
so im doing some researching since i just got my skunk2 coils, now i could use some new wheels. I want something that will look good with the stock suspension (EX) and then ill drop it.
so the real question is 17 or 18 5x100 or 5x114.3 and what offset because i really dont want any troubles ![]() |
#5 (permalink) | |
lowering the sidewall ratio from 55 to 45 would only throw off the speedo by 1.5%. alternativley getting a slightly wide tire like a 215 width, and then a 40 sidewall ratio will only throw off the speedo by 0.5%. which is the tire size of the Mugen Si. |
#7 (permalink) | |
offset is the distance between the centerline of the wheel and where it actually mounts to the hub.
![]() That should get you started... 7=¬þ Quote:
Removed the rest becasue I assumed you had an Si and don't want to confuse anyone. Last edited by PhoR11; 03-22-2008 at 01:11 PM. |
| aftermarket steering wheel options | vtec_marine | Inside and Out | 26 | 07-04-2007 03:28 AM |
| Wheel options... you know the drill. | 2moredoors | Photoshop | 4 | 04-21-2007 03:02 AM |
