ride differance between 15, 16s and 17s
is there a ride differance between 15,16,and 17s. im thinking of changing wheels but the ones that look great are mostly 17s. is there a differance as you vary tire size? i like the way the 16s on my LX sedan perform, how is the ride on 17s is it rough when you hit bumps or are they the same. also how is the road noise compared to the different tire size.i have an 09 corolla that im thinkin of swapping the steel tires out of also. im just wondering if i should buy new size tires and wheels for the vehicle. akso is there a differance in fuel ecomony when you change tire size and swap wieght.
Yeah, there is a difference in the ride... I went from my stock 16" rims to 18" with low profile tires. You definately feel every bump in the road especially when you hit a decent one.
As far as the fuel, I would say you might lose a couple miles to the gallon, but nothing noticable. |
8thcivic Sponsor
+ all of that.
more expensive and a stiffer, more rigid ride the larger you go. but it loosk cooler and the contact patch increases
Spencer@tirerack.com 1-877-522-8473 x690 *Remember to reference my name on Tirerack online orders* Use the link below to support the forum! http://www.tirerack.com/winter/index.jsp |
Contact patch only increases if you up the wheel width, not the wheel diameter. So, if you're going to go with a larger diameter, might as well go with a wheel width greater than stock size (>7"). The only downside to up-sizing your wheels is that with greater wheel size comes greater mass for the wheel/tire combination. I think 17" inch is a good middle ground when it comes to looks vs performance. It's going to be lighter than 18", yet still looks stylish. In some cases, I believe a 17" puts you closer to the ground too.
| Pros and Cons, 16s and 17s? | colourmyeyez | Wheel And Tire Upgrades | 9 | 02-15-2008 12:04 AM |
| Handling feels lighter on 16s?? | FastTimesAtFGHigh | Wheel And Tire Upgrades | 2 | 11-17-2007 11:34 PM |
| Will 15" steel wheels fit or do I need 16s? | Piotrush | Wheel And Tire Upgrades | 0 | 09-22-2007 08:25 PM |
| 17s on ex | 06CIVICFLBOI | Wheel And Tire Upgrades | 13 | 02-07-2007 04:30 PM |
| Si on 16s? | chilli si | Wheel And Tire Upgrades | 9 | 10-02-2006 04:00 PM |
