Beantown
Pics of a 18x8.5 rim
Hey guys....does anybody have any pics of an 18x8.5 rim on a coupe....just ordered some and wanna see by how much they will stick out...the offset is 45....also i fit them with 215 tires....anybody have any experience with this size on that size rim??? thanks
homeboy![]() Last edited by homeboyv; 02-19-2008 at 09:07 AM. |
Call and cancel your order. 215's on a 8.5" rim!!! C'mon. Next you'll be asking us about air suspension. But since you asked...
The wheel/tire combo will stick out an additional 19mm(3/4 inch) past stock si wheels if you run 215's. If the car is dropped, it won't stick out too far. Just so you know though...as far as I know, this "look" isn't "in" anymore, and where I come from...it never was. Don't plan on going to any "meetups" with other 8th enthusiasts. They WILL laugh. Sorry about being blunt. Don't feel bad, it's just my opinion. Anyone else care to chime in on this one? |
According to this wheel size calculator, a 215 size tire should only be used for wheel widths up to 8 inches. In your case, it'd be from 18x6 to 18x8. I'd suggest either a 225 or a 235 (depending on the look/performance you want). Here's the link to a pretty good calculator for you:
Wheel / tire size calculator / comparer - WHEELSMASTER |
If you mounted a 235/40/17 on the 18 X 8.5" rim, wheel.tire would stick out 29MM more than stock. (1 1/4") Get out your ruler, stick it on the sidewall of the tire, and see if you can live with an additional 1 1/4"s. More importantly, are the going to rub? Will you be lowering your car?
Beantown
haha...no worries i called tirerack this morning and told them to change the tires to 225....i chose the 215's cuz thats what tirerack recommends on this rim...not sure y...according to tirerack these 225's with 18x8.5 should not rub...i will be buying the hfp suspension kit to lower the car about an inch...
Here's an Idea of what it will look like with the 225. Pic of NA06Si Fg2
![]() Here's the link to his thread for more pics. *UPDATE* Gram Lights with Center Caps |
#15 (permalink) |
8thcivic Sponsor
18x8.5 +45 wearing 225/40/18 tires and lowered on Eibach Sportlines...fits perfectly, zero rubbing.
Jonathan - www.z1auto.com - 631-863-3820 GT-SPEC FENDER BRACE PRE-ORDER! http://www.8thcivic.com/forums/z1-pe...-preorder.html Check out our BLOG for: -Customer rides -New products -Original articles http://cornerbalance.wordpress.com/ |
#16 (permalink) |
^^^^^ how much is the eibach sportlines dropped? cuz i'm running tein s-tech and it only rubs minor in the rear.. rubbing agains the plastic piece on the driver side where the plastic covers the fuel pipe or whatever you call it..... you might wanna check yours.. nothing major though....
but here's my gramlights 57F 18x8.5 +45 225/40/18 ![]() ![]() |
#20 (permalink) |
When I placed my order, they insisted that a 18x8 38mm offset would fit fine with no rubbing. I hadent seen many setups on FGs with a 38 offset. The width should be fine since most of you guys are running the 18x8.5 wheels. It's kinda tough to tell by some of the pics.....does the 38mm sit flush with the fender/in a bit/ or sticks out of the fender?
| anyone w/ pics of a polished or chrome rim on asm? | KameraBoy | Wheel And Tire Upgrades | 2 | 06-16-2007 03:16 PM |
| 5 Zigen or Kazera rim pics needed! | hybrid civic | Wheel And Tire Upgrades | 1 | 05-23-2007 01:33 AM |
| 18x8.5 | Fg2ner | Wheel And Tire Upgrades | 0 | 03-17-2007 08:10 AM |
| The NEW rim HOTNESS for WHITE SI's - PICS | 2006exsedan | Wheel And Tire Upgrades | 45 | 03-02-2007 09:36 AM |
| 18x8.5 | Showtime | Wheel And Tire Upgrades | 16 | 05-12-2006 11:13 PM |
