Click Here
Old 02-02-2008, 11:27 AM   #1 (permalink)
is b0osted!
Civicn33b's Avatar
Josh
225/40/18's or 215/40/18's with sportlines?!
im about ready to install my sportlines but i have to take off these BFG 225/45/18 moster truck tires that are currently on there?!? i dont want to scrub... what size would you guys recommend? ryry, jeshua and all the other wheel guru's your input is highly valued and welcomed
"oh no he dit'en"
Civicn33b is offline
Old 02-02-2008, 11:28 AM   #2 (permalink)
inyong1988's Avatar
Junction Produce
i run with 215/40/18.
you shud rub with 225.
I have same set up btw.
inyong1988 is offline
Old 02-02-2008, 01:01 PM   #3 (permalink)
is b0osted!
Civicn33b's Avatar
Josh
awsome anyone else?
"oh no he dit'en"
Old 02-02-2008, 03:00 PM   #4 (permalink)
is b0osted!
Civicn33b's Avatar
Josh
anyone?
"oh no he dit'en"
Old 02-02-2008, 05:10 PM   #5 (permalink)
is b0osted!
Civicn33b's Avatar
Josh
seriously, anyone?!?1
"oh no he dit'en"
Old 02-02-2008, 05:28 PM   #6 (permalink)
24boosted's Avatar
I'm on 18x7.5 with an aggressive offset on 225/40 no issues.
24boosted is offline
Old 02-02-2008, 07:33 PM   #7 (permalink)
is b0osted!
Civicn33b's Avatar
Josh
im on 8" wide rims, but you still think ill be fine?
"oh no he dit'en"
Old 02-02-2008, 09:02 PM   #8 (permalink)
24boosted's Avatar
Depends on the offset. Some people have posted their specs as well.
18" Wheels...Post them up!
Old 02-03-2008, 01:52 AM   #9 (permalink)
Caper's Avatar
225/40R18 Should be fine.
215/45R17 24.6 inch diameter Stock
225/40R18 25.1 inch diameter Recommended
225/45R18 26.0 inch diameter Your current
Caper is offline
Old 02-03-2008, 12:59 PM   #10 (permalink)
24boosted's Avatar
Diameter isn't everything if you have 215s on low offset wheels and a low drop it's still going to rub.
Old 02-03-2008, 03:09 PM   #11 (permalink)
Caper's Avatar
I realize this... but he has Sportlines which I also have and I am running 17x8 with 225/45R17 that have a 45mm offset and 5mm spacer so 40mm offset and no rubbing. I don't believe that the g-games are a really aggressive an offset.
You would probably want to start worrying about rubbing below 38mm.
And you just said yourself: I'm on 18x7.5 with an aggressive offset on 225/40 no issues.
Was just trying to put it in perspective of the various heights of the tires for him. But yes offset does obviously play a factor as stated in previous posts.
Caper is offline
Old 02-03-2008, 04:00 PM   #12 (permalink)
is b0osted!
Civicn33b's Avatar
Josh
ya i be;ieve my offset is like +42
"oh no he dit'en"
Sportlines and 18's??? rubbing??? help DeDonDeRosa Suspension and Brakes 5 05-22-2007 09:44 AM
sportlines and 18's pdiddy2386 Suspension and Brakes 2 05-18-2006 11:25 PM
No 18's for LX? RODSCIVIC Civic Coupe And Sedan 16 04-20-2006 05:43 PM
