Click Here
Old 12-22-2007, 05:42 PM   #1 (permalink)
help on fitment issues
Im looking to buy some Rota 18x7.5 5x100 offset 48 rims, but the seller said they wont fit on my 2007 civic sedan because of they have to get the hub bored out to fit my car.the wheels have a 56.1hb. Is it true? it wont fit my car because of the hub bore? also, would 18x7.5 wit 48 offset fit well on my car without any problems?
llalm is online now   Reply With Quote
Old 12-22-2007, 06:33 PM   #2 (permalink)
fiji-blew's Avatar
is 5x100 the bolt pattern?
fiji-blew is offline   Reply With Quote
Old 12-22-2007, 07:06 PM   #3 (permalink)
nej_civic's Avatar
5x114.3 is the correct bolt pattern for us
nej_civic is offline   Reply With Quote
Old 12-22-2007, 07:45 PM   #4 (permalink)
02civicsi's Avatar
I am the Juggernaut!!!
The OEM wheels have a 2.5" or 63.5mm bore. Yeah so it sounds like you're SOL or you could be adventurous & get the hub bored out. I've heard of one guy who had it done. If you decide to do it you would need to bore the hub bigger by .291" or 7.4mm to fit.
02civicsi is offline   Reply With Quote
Old 12-22-2007, 07:53 PM   #5 (permalink)
dt07Si's Avatar
Dave
Although its not the size I would pick the width and offset would work. But find a set of wheels that has the right bolt pattern
dt07Si is offline   Reply With Quote
Old 12-24-2007, 05:16 PM   #6 (permalink)
i thought 5 lugs are unniversal? both 5x100 and 5x114 would fit?
Old 12-25-2007, 12:15 AM   #7 (permalink)
dt07Si's Avatar
Dave
not without an adapter.
5 x 100 and 5 x 114.3 are two completely different bolt patterns.
Old 12-25-2007, 01:48 AM   #8 (permalink)
aki
aki's Avatar
Resident Si Sedan Hater
u need 5x114.3.
FYI our hub bore is same as RSX, 64.1--not 63.5mm.
aki is offline   Reply With Quote
Old 12-25-2007, 01:51 AM   #9 (permalink)
that is what the "x100" or x114.3" stands for. its the distance determined by that measure depending on how many bolts are being used.
LucasBlack is offline   Reply With Quote
Old 12-25-2007, 10:35 AM   #10 (permalink)
02civicsi's Avatar
Duely noted. I just measured one of my OEM wheels & used a converter to get the metric equivalent.
Magnaflow catback fitment issues redguym Bolt-Ons And All-Motor 1 12-10-2007 03:12 PM
IMPORTANT: Fuel Return Kit and Fuel Filter Issues blueroadster Forced Induction And Nitrous 196 04-27-2007 01:09 PM
Red "H" emblems for 07 sedan...fitment issues...merged Rocco Inside and Out 19 01-24-2007 11:03 PM
Wheel fitment issues cmf Wheel And Tire Upgrades 2 06-26-2006 01:16 AM
