#702 (permalink) |
Aggressive wheels would be good, but that thought gets very costly very fast. Going to a 15.5Lb sturdy wheel over the factory 23lbs. I guess I should phrase this differently. Looking for the widest wheel I can use in 17". What offset is needed to do it and such...
Thx |
#703 (permalink) | |
Chillaxin...™
the +33 on you example is the offset of the wheel. Offset is how flush or how much the wheel will stick out from the fender. The lower the number, further out it is. Stock SI is +45 so if you go higher than that the the wheel is more inside the fender. The lower it goes the more the wheel extends towards the outside. Hope that makes sense. Thats the only way I can explain it with out using much technical terms. |
#704 (permalink) | |
![]() As pgFA said the lower the offset the further the wheel will stick out. If your considering 17 x 8 +33 I would be interested to hear what your dropped on if your lowered and what size tires you plan on running. |
#707 (permalink) |
Hidy Ho Neighbor
Anyone know if the 18x7 45mm offset 215/40-18 (HFP Wheel Fitment), which I have now, will work if I change to 225/45-18 tires?
I already know the 7" wide rim will work for that tire size. What I'm concerned about is whether the larger O.D. (+1.2") and wider section width (+0.4") will rub.
#719 (permalink) |
im running 17x8 225/45R17 +45 offset with a 15mm spacer clearing Spoon Sport Calipers No rubbing issues what-so-ever. I am going to be lowering her about 1" all around on Buddy Club N+ Coilovers. I am jsut waiting to finish my engine and get it back in.. Too low to work on the floor and jack if I drop the car.
LinkBack to this Thread: http://www.8thcivic.com/forums/wheel-tire-upgrades/6934-wheel-fitment-recipe-wheel-offsets-work.html
| 18 | This thread | Refback | 01-14-2008 12:34 PM | |
| 18 | This thread | Refback | 01-14-2008 09:57 AM | |
| 18 | This thread | Refback | 01-14-2008 08:21 AM | |
| 18 | This thread | Refback | 01-14-2008 08:17 AM | |
| Wheel Fitment Recipe - wheel offsets that work - 8th Generation Honda Civic Forum | This thread | Refback | 12-10-2007 05:51 PM | |
| Wheel fitment... Now maybe a problem | DumbasSi | Wheel And Tire Upgrades | 26 | 04-27-2006 06:10 PM |
| Wheel offsets? | Jake | Wheel And Tire Upgrades | 1 | 01-06-2006 12:35 PM |
