Wheel Fitment Recipe - wheel offsets that work - Page 30 - 8th Generation Honda Civic Forum
Closed Thread
LinkBack (10) Thread Tools Display Modes
Old 05-01-2008, 09:19 AM   #581 (permalink)
dt07Si's Avatar
Dave
Originally Posted by smokenrowboy View Post
I wonder if a +32 offset would have fitment issues. Has anyone here run 9/9.5 in. wide rims?
I am running a +32 offset on a 17 x 8 with 215/45/17's
At my height I couldn't get away with 225/45's without rubbing a lot. And even with 215's and a fair amount of negative camber, I rub occasioanly, but its all good.
A couple people have run 9's, but they are around +40 offsets. I don't know of anyone that has run 9.5's, but I wouldn't doubt someone has with a wide body.
dt07Si is offline
Old 05-01-2008, 11:50 AM   #582 (permalink)
Si Speed 317's Avatar
Dan- GT30R Fanboi
What is the widest tire we can go on a Stock setup without sticking out / rubbing?
These are the rims I'm looking at getting. I have 2 choices for 18" rim sizes:
18 x 7.5 (42mm offset) with IDK tires
OR
18 x 8.5 (35mm offset) with IDK tires
I'm lowered on HFP, which would work better? I'm leaning towards 18x8.5 with 35mm offset... Thanks in advance!
Si Speed 317 is offline
Old 05-01-2008, 07:23 PM   #583 (permalink)
06 Civic Ex's Avatar
𝑺 my 𝒅
18x7.5 +43 wrapped in 235/40ZR18
im not dropped but looking to get dropped probably HFP soon.
will it work?
06 Civic Ex is offline
Old 05-06-2008, 11:41 AM   #584 (permalink)
realxlai's Avatar
M. Bison
18x8 35+ dropped on sportlines... will this work? what tire width should i run?
realxlai is offline
Old 05-06-2008, 02:57 PM   #585 (permalink)
robertw's Avatar
I have been considering some new rims and ran into some Rota Grids.
ROTA Wheels - Grid
17 x 7.5 +35/+45/+48 5h x 114.3
What offset would be recommended if I have the HFP suspension, and what would I need if I didn't have it (stayed stock)?
I am wondering if there would be a big difference.
robertw is offline
Old 05-06-2008, 03:10 PM   #586 (permalink)
JeShUa's Avatar
50 LOW
will it work?
hfp isnt a drop. Weak offset. Stupid tire size.
215/40 if you dont mind a little stretch. 225 for more sidewall, but will require a little more camber.
ROTA Wheels - Grid
Stock is 45 offset. Rota ftl.
JeShUa is online now
Old 05-06-2008, 03:12 PM   #587 (permalink)
robertw's Avatar
Seriously what is wrong with Rota wheels?
Is it just a bad offset that will make the wheels looked tucked in or what? What would 48 look like?
robertw is offline
Old 05-06-2008, 03:20 PM   #588 (permalink)
JeShUa's Avatar
50 LOW
Rota is the payless of wheels. Nothing per se wrong with them. I would personally get 35. Slap yourself if you get 48. 45 is stock.
Old 05-06-2008, 03:24 PM   #589 (permalink)
robertw's Avatar
How will 35 look? I know nothing about wheels and offset.
robertw is offline
Old 05-06-2008, 03:26 PM   #590 (permalink)
JeShUa's Avatar
50 LOW
It will be closer to flush.
Old 05-06-2008, 03:28 PM   #591 (permalink)
robertw's Avatar
How far in would 45 be? ( I apologize I am a wheel noob, if you will)
robertw is offline
Old 05-06-2008, 03:37 PM   #592 (permalink)
realxlai's Avatar
M. Bison
45 is what your wheels look like now. higher the offset number the farther in, lower the offset number the more it'll sit out.
realxlai is offline
Old 05-06-2008, 08:48 PM   #593 (permalink)
dt07Si's Avatar
Dave
will it work?
Yes it will work, but personally it is not a width and offset I would run.
I agree.
Nothing is wrong with Rota's. If you don't have the money for a name brand wheel, or don't want to spend the money, there fine. People hate on them because they are inexpensive, very very common (especially in the Honda world), and there replica's of higher end wheels.
My first set of wheels were Rotas, they looked great IMO, they fit my budget (I was in high school), and I never had one problem with them. Now I'm older and making/saving more money, and I can afford something better. Not to mention if I had a tight budget on wheels, I would be more likely to buy a used set of nice wheels for around the same price and refinish them myself.
There are two factors that account for how far a wheel sticks out, or how sunken in it is. WIDTH and OFFSET.
45 is the same as stock, so the only difference is the width. So because they are a half inch wider, they will stick out a 1/4" further on either side. 1/4" on the outside half of the rim, 1/4" on the inside half of the rim.
Got it?
This is true.
MY RANT...
Here is probably the only thing one needs to determine whether a wheel will fit or not, aside from reading what setups people have used in this thread.
1010 Tires Wheel Offset Calculator
Take the "Inner Clearance" number and the "Outer Position" number and use a RULER AND MEASURE!
I am not directing this to anyone on this page or anyone in particular in this thread. I am more than happy to try and help people with wheel/tire sizing, but when I see people post questions time after time about wheel/tire combo's that have already been done, and may even be on the list on the first page of this post, I will not reply to them anymore. It takes a little while to read through this thread, but I did it and many other people have done it also.
dt07Si is offline
Old 05-06-2008, 09:03 PM   #594 (permalink)
david3558's Avatar
David
Hey guys, I heard that If I got some Rota's I would need something called a hubcentric ring...my question is what size do I need, and where can I find them? Thanks
david3558 is offline
Old 05-08-2008, 10:51 AM   #595 (permalink)
bmcteg98's Avatar
Ben
18x8.5" +43 w/ Tein S-techs and 225/40/18 works. Had them put on last week and haven't rubbed yet.
bmcteg98 is offline
Old 05-12-2008, 01:43 AM   #596 (permalink)
dannyd86's Avatar
Danny
I was wondering if on my FG2 (soon to be lowered with a camber kit), I could get away with some 17x8" 35mm offset wheels, with the stock 215/45/17 tires.
Will these stick out too far and prob hit the fenders?
dannyd86 is offline
Old 05-12-2008, 01:55 AM   #597 (permalink)
dt07Si's Avatar
Dave
I'll give you a break because you only have 8 posts, but in the future read through threads before posting questions.
Refer to my post at the top of this page, that should answer your question.
dt07Si is offline
Old 05-12-2008, 02:03 AM   #598 (permalink)
dannyd86's Avatar
Danny
Occasional rub? Like when? What suspension setup?
dannyd86 is offline
Old 05-12-2008, 10:20 AM   #599 (permalink)
dt07Si's Avatar
Dave
Yeah occasioanl rub, it's not like it happens all the time. It happens when I hit big pot hots or bumps in the road.
I am lowered on TEIN SS's and I am lower than most if not all spring drops.
dt07Si is offline
Old 05-12-2008, 11:05 AM   #600 (permalink)
dannyd86's Avatar
Danny
Thanks. I think I'll be going with that wheel setup. Any pics?
dannyd86 is offline
Closed Thread
LinkBack to this Thread: http://www.8thcivic.com/forums/wheel-tire-upgrades/6934-wheel-fitment-recipe-wheel-offsets-work.html
Mags offset? - Club Civic Quebec :: Forum This thread Refback 08-28-2011 03:51 PM
Honda Club Brasil • Exibir Tópico - Qual off-set do New Civic? This thread Refback 08-07-2011 06:34 PM
8th Gen FAQ's index - Club Civic Quebec :: Forum This thread Refback 08-07-2011 10:03 AM
Fs: Rare Civic Type R Wheels (FD2R) - Beyond.ca - Car Forums Post #0 Refback 07-23-2011 05:12 AM
Fs: Rare Civic Type R Wheels (FD2R) - beyond.ca car forums community for automotive enthusiasts Post #0 Refback 07-04-2011 05:35 PM
18 This thread Refback 01-14-2008 01:34 PM
18 This thread Refback 01-14-2008 10:57 AM
18 This thread Refback 01-14-2008 09:21 AM
18 This thread Refback 01-14-2008 09:17 AM
Wheel Fitment Recipe - wheel offsets that work - 8th Generation Honda Civic Forum This thread Refback 12-10-2007 06:51 PM
Wheel fitment... Now maybe a problem DumbasSi Wheel And Tire Upgrades 26 04-27-2006 07:10 PM
Wheel offsets? Jake Wheel And Tire Upgrades 1 01-06-2006 01:35 PM
