Click Here
Old 04-23-2008, 09:21 PM   #561 (permalink)
hey guys i need help i found some buddy club rims on the rsx forum and wanted to see if they will fit my 08 lx coupe.... they are
5x114.3, 17x7 with 42 offset.... could i run 215/45 or 225/45... what would look good and will this stick out at all or stick in a bit?? and how about lowering it? hfp suspension good drop?? sorry for all the questions i dont know too much about rims/suspension as u can see....
sf08ggm is offline
Old 04-24-2008, 06:57 AM   #562 (permalink)
dt07Si's Avatar
Dave
That setup will work with absolutely no problem, whether your at stock height or your slammed on coilovers.
You could run a 225/45 if you want to put more rubber down on the ground. Buddy Clu wheels are nice but persoanlly I would try and find a 17 x 8 with a similar offset.
And yes the HFP suspension is a nice drop if your looking for a conservative drop and better handling. If you want to go low and aren;t as concerned with the handling the HFP setup isn't for you.
dt07Si is offline
Old 04-24-2008, 06:51 PM   #563 (permalink)
hmmm thanks for the info bro.... i found some rota wheels 17x7.5 with 45 mm offset... would that work good with 225/45's?? the lower the offset the more the wheels stick out right?
sf08ggm is offline
Old 04-24-2008, 08:34 PM   #564 (permalink)
dt07Si's Avatar
Dave
correct. And yes you should have no problem with a 225/45 on that size wheel.
17 x 8 +32 w/ 215/45/17 lowered on TEIN SS coilovers
dt07Si is offline
Old 04-24-2008, 09:03 PM   #565 (permalink)
JeShUa's Avatar
Keepin` it Phresh
Camber? Wait.. you're rolled.
JeShUa is offline
Old 04-24-2008, 09:11 PM   #566 (permalink)
dt07Si's Avatar
Dave
Nope not rolled, and yes I am actually running a good amount of negative camber. 4 Ingalls camber bolts, all the way negative up front, and skunk 2 rear camber arms, running around -2.0 to -2.5 in the rear. The shot is deceiving.
dt07Si is offline
Old 04-24-2008, 09:26 PM   #567 (permalink)
friedk's Avatar
He's got smaller tires also. Less rubb.
friedk is offline
Old 04-24-2008, 11:56 PM   #568 (permalink)
JeShUa's Avatar
Keepin` it Phresh
Real. Mine is only -1.5.. -2.5 might be nice but idk.. I wouldnt need camber arms to run that lawl.. then idk if I could run my tsx wheels
JeShUa is offline
Old 04-25-2008, 12:28 AM   #569 (permalink)
friedk's Avatar
Rub on your basics to hell and back with that offset and that camber. lolz
friedk is offline
Old 04-25-2008, 06:54 AM   #570 (permalink)
dt07Si's Avatar
Dave
What? You wouldn't have -2.5 degrees of static negative camber just from lowering the car. And why wouldn't you be able to run TSX wheels?
dt07Si is offline
Old 04-25-2008, 07:04 PM   #571 (permalink)
damn bro sick car!! GG ftw.... i love those rims!!
sf08ggm is offline
Old 04-25-2008, 09:41 PM   #572 (permalink)
dt07Si's Avatar
Dave
thanks man!
dt07Si is offline
Old 04-26-2008, 02:35 AM   #573 (permalink)
jono's Avatar
I just bought some 17x7.5 +48
What would be the best tire size? I have a Si Sedan lowered on Eibach Sportlines. should i keep the 215-45-17 or go with a 225-45-17? Would a spacer be needed?
jono is offline
Old 04-26-2008, 01:13 PM   #574 (permalink)
dt07Si's Avatar
Dave
You won't NEED a spacer, however I think the car would probably look better if you used a 5 or 10 mm spacer.
As far as tires you could go with either size.
dt07Si is offline
Old 04-27-2008, 03:33 PM   #575 (permalink)
I am looking at 18x7.5 +45mm offset Motegi DP6 rims for my 07 sedan no drop. Will it work?
Ryan8th is offline
Old 04-29-2008, 12:42 AM   #576 (permalink)
Si Speed 317's Avatar
Dan
Think of new rims, they're 18x7.5 with 42 offset... What would be the correct tire size? And would they work with HFP drop?
Si Speed 317 is offline
Old 04-29-2008, 12:44 AM   #577 (permalink)
friedk's Avatar
delete
friedk is offline
Old 04-29-2008, 12:44 AM   #578 (permalink)
friedk's Avatar
These both will fit fine. Run 225s with 7.5".
friedk is offline
Old 04-29-2008, 10:20 AM   #579 (permalink)
Garrick Mundy
whats the best size rim and tire for the eibach sportline drop? i want it so it gives the apperance of being tucked, but without rubbing what so ever
Show Stoppa FG1 is offline
Old 05-01-2008, 03:45 AM   #580 (permalink)
smokenrowboy's Avatar
FMInterf00ler0_o
I wonder if a +32 offset would have fitment issues. Has anyone here run 9/9.5 in. wide rims?
smokenrowboy is offline
LinkBack to this Thread: http://www.8thcivic.com/forums/wheel-tire-upgrades/6934-wheel-fitment-recipe-wheel-offsets-work.html
18 This thread Refback 01-14-2008 12:34 PM
18 This thread Refback 01-14-2008 09:57 AM
18
