Click Here
Old 03-06-2008, 06:13 PM   #461 (permalink)
nastynogales's Avatar
Instead of 225/40, would 215/40 be able to give me that stretched tire look if i have 18x8 33offset?
Would that have more clearance, esp w/ a pro-kit drop (1")?
i really don't want to roll or have to put a camber kit
nastynogales is offline
Old 03-06-2008, 11:19 PM   #462 (permalink)
dt07Si's Avatar
Dave
Originally Posted by Piotrush View Post
To the person with the 17x8+35 - were you lowered at all? If so how much of a drop? I plan on going the HFP route with a 235-40 tire. Thanks.
There are a couple people running that spec wheel on an 8thgen that I know of. One is lowered w/ a 215/45 and the other is not lowered with a 225/45. With an HFP drop you should be able to get away with a 225 but I honestly wouldn't go with a 235 with that low of an offset.
I will be running 17 x 8 +32 dropped on TEIN SS coilovers and I am going to have to run a 215/45 with a fair amount of negative camber. Without being able to adjust your camber you might run into some rubbing.
dt07Si is offline
Old 03-06-2008, 11:26 PM   #463 (permalink)
GALAXY~SI's Avatar
Kurt
hmmmmmmmmmm
GALAXY~SI is offline
Old 03-06-2008, 11:28 PM   #464 (permalink)
GALAXY~SI's Avatar
Kurt
mean you'll be sitting a bit past the fender you kinda have to run a coil over so you can lower it just right and you'll need a lot of camber very aggressive i like i like.. you my sir are daring
Old 03-07-2008, 08:10 PM   #465 (permalink)
dt07Si's Avatar
Dave
Haha, in the front they actually sit flush and I mean FLUSH with the fenders. In the rear they might sit a mm or 2 past the fenders but probably not even that much (and thats with -0.8 degrees of camber). I won't have to run that much negative camber, especially if I roll the fenders.
dt07Si is offline
Old 03-07-2008, 11:38 PM   #466 (permalink)
local318
hey guys im lookin into pickin up some enkei rpf1 type rc rims but the problem is that is 18X8.5 f and 18X9.5 rear. can that possibly fit? please help! need to know asap
local318 is offline
Old 03-08-2008, 12:20 AM   #467 (permalink)
GALAXY~SI's Avatar
Kurt
that's cool the camber should take car of it to be honest can't wait to see them this summer
Old 03-08-2008, 01:33 AM   #468 (permalink)
dt07Si's Avatar
Dave
No way your fitting a 9.5" wheel on a 8thgen without some serious fender and suspension modifications. Offsets would also help, but judging by the widths I'm guessing there pretty low.
dt07Si is offline
Old 03-10-2008, 03:16 PM   #469 (permalink)
rp215's Avatar
Ronnie
I want to kow what offset will give me a flush look:
17x7.5 +43
17x7.5+33
I am slammed on TEIN Basics btw.
I want to order today if possible if you guys can help!
No rubs! lol
rp215 is offline
Old 03-10-2008, 03:24 PM   #470 (permalink)
JeShUa's Avatar
Keepin` it Phresh
+33. You're not SLAMMED btw.
JeShUa is offline
Old 03-10-2008, 03:41 PM   #471 (permalink)
rp215's Avatar
Ronnie
Well my coilovers wont let me go any lower so I figured I was.
rp215 is offline
Old 03-10-2008, 04:03 PM   #472 (permalink)
CivicSi907's Avatar
Thomas
Will that work:
19x8.5 - 20mm offset 225/35/R19 with 1.6 Drop (Neuspeed Springs)
the wheels are also available with 45mm offset, what should i take?
CivicSi907 is offline
Old 03-10-2008, 04:03 PM   #473 (permalink)
JeShUa's Avatar
Keepin` it Phresh
This is slammed...
JeShUa is offline
Old 03-10-2008, 04:04 PM   #474 (permalink)
JeShUa's Avatar
Keepin` it Phresh
Originally Posted by CivicSi907 View Post
Will that work:
Thats very aggressive.. you'll NEED to roll your fenders, and IDK how much camber you'll need to run, but you can make it fit with quite a bit of work.
JeShUa is offline
Old 03-10-2008, 07:47 PM   #475 (permalink)
rp215's Avatar
Ronnie
Why 19"?
rp215 is offline
Old 03-10-2008, 09:36 PM   #476 (permalink)
dt07Si's Avatar
Dave
x2
Anythings possible...but for one I wouldn't rock 19's on an FA or FG let alone any Civic, and two with that width and offset you would be poking a good 20+ mm past the fenders.
dt07Si is offline
Old 03-12-2008, 09:48 AM   #477 (permalink)
CivicSi907's Avatar
Thomas
Originally Posted by rp215 View Post
Why 19"?
looks better!
what will fit or look better:
18x8.5 with 35mm offset
or
18x8.5 with 45mm offset
with
1.6" Drop ???
Old 03-12-2008, 12:39 PM   #478 (permalink)
BWT: Enkei EVO-5 (Hyper Black) Wheels/Rims - EVO5
Im looking at the third and sixth one, what is the difference? And will both fit on my civic (8th gen, of course)?
potatoe is offline
Old 03-12-2008, 05:28 PM   #479 (permalink)
Piotrush's Avatar
Peter
Just mounted the following:
wheels: Enkei GTC-01 17x8 +48
tires: 245-40-17 Potenza RE01R
haven't seen noticed rubbing issues yet. I did several full turns with the wheels turned 100% in both directions and nothing. Hopefully it won't rub when I'm taking sharp turns and body roll enters the equation.
Piotrush is offline
Old 03-13-2008, 12:06 AM   #480 (permalink)
On stock suspension you could get away with a 235, but I would probably run a 225 either way. A 235 on a 7.5" wheel wouldn't look good IMO.
Thank you.
mp3stang is offline
