Click Here
Old 02-15-2008, 06:40 PM   #441 (permalink)
The1SloR/T's Avatar
What is the Stock offset for a 2006 EX? (the 5 spoke silver wheels)
is it +45?
also, the wheels are 16x7 correct?
The1SloR/T is offline
Old 02-16-2008, 02:19 AM   #442 (permalink)
07NHBCivicSi's Avatar
Curtis
Im thinking of getting a set of wheels that are 17x8 +35 or +45. I saw on the list that they fit. I am hoping to run 225/45/17 but I also want to drop on Progress springs. Which offset would be best to use for the set up I want. thanks in advanced
2007 NHBP FG2 -°Fujita SRI°-°8th Stickers°
07NHBCivicSi is offline
Old 02-19-2008, 01:32 PM   #443 (permalink)
anyone ever try running a 16x9 inch wheel with a 25mm offset? Got a set of three piece BBS rs's I wanna try on my si sedan...what do you guys think, too small?
adamk20 is offline
Old 02-19-2008, 05:14 PM   #444 (permalink)
dt07Si's Avatar
Dave
+35 would definitely look better but with a 225 you might have an occasional rub depending on your camber settings (ie. how much negative camber you are running).
If you want to play it safe run the +45, if you are willing to run a little more negative camber than stock, and buy front and possibly rear camber kits if you don't already have them then I would run a +35. What would really determine if you would rub with the Progress springs is, one how much negative camber you would gain just from the drop, and two what make and model of tire you would buy (some 225's are wider than others).
I am not sure if 16's clear the Si calipers, but even if they do I think they look too small on our cars. BBS RS's are sick wheels, but even a 17" set would look funny IMO, they flow better with older cars. BBS's FTW though
dt07Si is offline
Old 02-19-2008, 06:38 PM   #445 (permalink)
2007 Si Sedan
17X7.5 Wheel - 40 offset
I am on stock suspension right now. I would like to upgrade to the HFP suspension in the near future.
Which tire size should I go with?
225/45/17
or
235/40/17
mp3stang is offline
Old 02-19-2008, 06:54 PM   #446 (permalink)
Curtis
Alright, cool thanks. I was planning to run the Kumho Ecsta SPT or something close to the price range and tire.
Old 02-19-2008, 07:54 PM   #447 (permalink)
mikeatr's Avatar
Mike Lee
rota torque 17x8 48mmoffset work?
will 17x8 48 offset work on my si coupe? and wat tire size do u guys recoommend????
mikeatr is offline
Old 02-23-2008, 04:52 PM   #448 (permalink)
GALAXY~SI's Avatar
Kurt
im gonna be running 17x7 35mm offset in the front and 17x8 35mm offset in the rear and im putting 215 45 17 on i wanna go for that stretched look in the back see how i will like it..
I just wish the front were 17x8 as well dammit
GALAXY~SI is offline
Old 02-23-2008, 10:08 PM   #449 (permalink)
dt07Si's Avatar
Dave
Originally Posted by mp3stang View Post
2007 Si Sedan
225/45/17
or
235/40/17
On stock suspension you could get away with a 235, but I would probably run a 225 either way. A 235 on a 7.5" wheel wouldn't look good IMO.
No problem. I don't know how well that tire performs but a 215 on an 8 will look fine (check out Smoots car).
Depends on if you are lowered or on stock suspension. Normally i would say a 215/45/17 or a 225/45/17.
Sounds good man, I'm waiting for my wheels to show up Monday. I will be running a 215/45/17 Goodyear Eagle f1's on my 17 x 8's.
And yeah its too bad your new setup won't be 17 x 8 all around.
dt07Si is offline
Old 02-24-2008, 05:03 AM   #450 (permalink)
Could someone please confirm, verify, and guarantee if the spec below..
Wheel: 17x17 35 offset
Tire: 215/45-17
..would work for an EX coupe with HFP suspension?
TIA!
6SPDMT is offline
Old 02-24-2008, 11:42 AM   #451 (permalink)
dt07Si's Avatar
Dave
Tire: 215/45-17
TIA!
That would definitely work, and if you want to verify it for yourself just take a ruler and measure 10mm out front the outer edge of your stock wheels. You should have more than enough clearance considering you want to run a 215, on a 7" wheel, and with HFP suspension.
dt07Si is offline
Old 02-25-2008, 05:22 PM   #452 (permalink)
Thanks dt07Si.
6SPDMT is offline
Old 02-25-2008, 11:29 PM   #453 (permalink)
dt07Si's Avatar
Dave
Thanks dt07Si.
No problem man.
I know its the internet but its still weird hearing people call you by your username.
dt07Si is offline
Old 02-28-2008, 12:49 PM   #454 (permalink)
CivicSi907's Avatar
Thomas
Can i put 215/35 R18 tires on a 18" Rims ? Is it valid ?
These are 215/35 R18
I think the rolling circumference isnt correct? Can anyone confirm it?
CivicSi907 is offline
Old 02-28-2008, 07:17 PM   #455 (permalink)
just wondering
i have a stock ride, i want to get 225/40/18, with an 18 x 8 rim. The rim comes with 45 mm offset or 37mm offset,
which one would rub less and which one would look better??????
thanks
gixxersi is offline
Old 03-01-2008, 01:11 PM   #456 (permalink)
RobertsD's Avatar
Dave
18x8 35mm offset 225/40-18 (HFP Suspension)
I know you have this on your list, but I want to make sure that I will have absolutely no problems doing this
RobertsD is offline
Old 03-01-2008, 02:39 PM   #457 (permalink)
pgFA's Avatar
Paolo
The overall diameter of the wheel is going to be too small compared to stock. Your speedo will read 62 (61.7) if your going 60. Plus less protection for your wheels. I would suggest 215/40/18 or 225/40/18.
pgFA is online now
Old 03-01-2008, 03:10 PM   #458 (permalink)
J-StarR's Avatar
I'm shopping around for some track rims right now and found a set or Rota Slipstreams with the following dimensions:
16 x 8.0 +48 5h x 114.3
The offset is what worries me the most. For my winter tires I had a set of prelude blades that had an offset of 50 but they were 7" wide so I'm not sure if the extra inch will rub against the shock body. Does anyone run with 16x8's on their Si?
J-StarR is offline
Old 03-03-2008, 12:35 AM   #459 (permalink)
i plan on running 18x8 +35 on 225/40/18.
Will these rub on a Si coupe at stock height?
Will it rub with the HFP suspension?
07k20si is offline
Old 03-03-2008, 03:43 PM   #460 (permalink)
Piotrush's Avatar
Peter
To the person with the 17x8+35 - were you lowered at all? If so how much of a drop? I plan on going the HFP route with a 235-40 tire. Thanks.
Piotrush is offline
