Click Here
Old 12-18-2007, 05:42 AM   #381 (permalink)
Gixstars's Avatar
18x7.5 48 offset rims and 225/40-18 tires. How does this sound??? Who has this already?
Gixstars is offline
Old 12-18-2007, 05:55 AM   #382 (permalink)
dt07Si's Avatar
Dave
Complex is running a 17 x 7.5 with a 48mm offset of his Time attack Volk TE37's with a 225 tire I believe.
dt07Si is offline
Old 12-22-2007, 01:59 PM   #383 (permalink)
PWRDByAdobo's Avatar
Bryan Pascual
18x7.5 +35 w/ 225/40 R18 fits...but you need to roll the front fenders a bit with a 1.5-1.75in drop.
PWRDByAdobo is offline
Old 12-23-2007, 12:04 PM   #384 (permalink)
dt07Si's Avatar
Dave
There is nothing to roll on the front fenders, its just a plastic fender liner. You can roll the rear fenders though.
dt07Si is offline
Old 12-25-2007, 01:17 AM   #385 (permalink)
Gixstars's Avatar
If my car is stock height then do I need to worry about rubbing still?
(again 18x7.5 w/ 48 offset)
Gixstars is offline
Old 12-28-2007, 05:47 AM   #386 (permalink)
I have a question for you guys, if you're afraid that your rims will get scratched when you want them balanced or mounted are there special shops around that handle these wheels or a regular shop is fine?
Si_Jeff is offline
Old 12-28-2007, 03:26 PM   #387 (permalink)
dt07Si's Avatar
Dave
I wouldn't be the slightest bit worried about rubbing with that wheel size on stock suspension.
I would go wo a reputable shop and make it known that you want them to be careful with the wheels. Most good shops no what there doing though and are careful with wheels that their working with.
dt07Si is offline
Old 12-29-2007, 09:09 AM   #388 (permalink)
Ray
anybody advise against
17x8 RPF1s +35
w/ 225/45-17??
will it cause any rubbing?
ray3111 is offline
Old 12-29-2007, 09:26 AM   #389 (permalink)
1.8L FG KiDd's Avatar
FrAnCiS
1.8L FG KiDd is offline
Old 12-29-2007, 05:42 PM   #390 (permalink)
dt07Si's Avatar
Dave
17x8 RPF1s +35
w/ 225/45-17??
I am going for that exact setup. It really depends on your drop, and amount of negative camber.
Worst case i will be running a stock 215/45/17
dt07Si is offline
Old 12-30-2007, 04:03 AM   #391 (permalink)
Ray
so i should jus put off on the wheels until i get my suspension in "/
ray3111 is offline
Old 01-04-2008, 06:09 AM   #392 (permalink)
17x8 offset +55 would this fitment fit on a 07 civic ex sedan?
JDM FA5 is offline
Old 01-04-2008, 01:13 PM   #393 (permalink)
Help a brazillian member.... I have doubts, I go to buy 18" wheels and want to use tires 225/40/18 and would like to know which offset would have that to be the wheels to use in my car without rub...
I am using eibach in my car, photo below:
Pedro
Pedro Hamdan is offline
Old 01-04-2008, 03:09 PM   #394 (permalink)
anyone?
JDM FA5 is offline
Old 01-04-2008, 03:13 PM   #395 (permalink)
JeShUa's Avatar
Keepin` it Phresh
I'd run some 5mm spacers with those.
JeShUa is offline
Old 01-07-2008, 11:41 PM   #396 (permalink)
stock tires on a 17x8 rim? will that work?
kirks07si is offline
Old 01-08-2008, 01:40 AM   #397 (permalink)
dt07Si's Avatar
Dave
x2
[IMG ]http://img292.imageshack.us/img292/7411/exs9ga7.jpg[/IMG]
[IMG ]http://img186.imageshack.us/img186/4759/exs8gj6.jpg[/IMG]
Pedro
Mainly depends on the width of the wheel.
Yes. A 215 is designed for a 7"-8" wide wheel. However some 215's may appear to have a mild stretch and other will not, just depends on the make and model.
dt07Si is offline
Old 01-10-2008, 01:54 PM   #398 (permalink)
s0opa_Si's Avatar
i dont know if this has been answered
but would this setup be wise?
17x8, 5x114, 48 offset?
s0opa_Si is offline
Old 01-11-2008, 06:25 PM   #399 (permalink)
klk15's Avatar
Kerry
will a 17x7 35 mm offset wheel tires are 215/45/17 rub on a FA5 with Tein S tech's installed (1.5 inch drop)?
klk15 is offline
Old 01-11-2008, 07:16 PM   #400 (permalink)
dt07Si's Avatar
Dave
You would lose 16mm of clearance between the inner edge of the wheel/tire and the strut. Which may very well cause the tire to rub against the strut depending on the tire size, I wouldnt advise such a high offset on a 17 x 8, because you would probably end up having to space them out to eliminate inner rubbing.
I think you would be fine.
dt07Si is offline
LinkBack to this Thread: http://www.8thcivic.com/forums/wheel-tire-upgrades/6934-wheel-fitment-recipe-wheel-offsets-work.html
18 This thread<
