Click Here
Old 07-15-2007, 10:47 PM   #261 (permalink)
TWK20si's Avatar
Kevin
Will 18x8 +40 offset lowered on Tein SS's work?
TWK20si is offline
Old 07-16-2007, 02:06 AM   #262 (permalink)
djpreview's Avatar
what size tire?
might rub unless no drop
djpreview is offline
Old 07-16-2007, 10:57 AM   #263 (permalink)
TWK20si's Avatar
Kevin
pry 225/40/18. Would 18x7.5 +40 work better then 18x8?
TWK20si is offline
Old 07-17-2007, 04:08 PM   #264 (permalink)
mocsman's Avatar
Hi newby here! Anyone running on Enkei Evo 5s? I'm thinkin bout getting the bronze (choice of +35 or +45mm offset) for my black 07 si sedan. Can u tell me what u think? appreciate ur comments.
mocsman is offline
Old 07-17-2007, 08:51 PM   #265 (permalink)
Tim
non-Cilantrist
Tim's Avatar
Quite possibly, yes. That extra half inch of wheel width does contribute to the overall width of the contact patch. It's not a huge difference, but it could make a difference between rubbing and not rubbing, depending on the suspension upgrades.
Tim is offline
Old 07-17-2007, 08:52 PM   #266 (permalink)
Tim
non-Cilantrist
Tim's Avatar
Welcome!
What size is the wheel and tire you're looking at? Personally, to play it safe, I'd go with the 45 mm offset. It will give you the breathing room to lower your car or make other suspension upgrades.
Tim is offline
Old 07-22-2007, 02:58 PM   #267 (permalink)
black07coupe's Avatar
"18x8 MB Motoring Rev
40mm offset
5x114.3mm
Polished finish, overall finish is very good, clear coated from factory, no peels.
Some blems as seen on the picture gallery.
Falken Azenis ST115 Performance Summer tires
245/40ZR/18
They are still in good condition, holds pressure. The ex-front tires are worse off than the rears cause they came off a front wheel drive vehicle.
Chrome lugnuts included and a special adaptor for the lugnuts "
Anyone know if these will fit on my coupe? The suspension is stock.
black07coupe is offline
Old 07-23-2007, 01:55 AM   #268 (permalink)
would an 18x7.5 +35 offset work on an HFP suspension 06 Si?
junsu is offline
Old 07-23-2007, 02:23 AM   #269 (permalink)
Tim
non-Cilantrist
Tim's Avatar
Yes. Yes it will.
Tim is offline
Old 07-24-2007, 04:38 AM   #270 (permalink)
Originally Posted by Tim
Yes. Yes it will.
how about an 18x8 +35 offset? thanks for the help.
junsu is offline
Old 07-24-2007, 08:46 PM   #271 (permalink)
how would 17x8 with a 45mm offset and a eibach sportline drop work? any rub?
amigochief is offline
Old 07-24-2007, 08:47 PM   #272 (permalink)
sorry, wrapped in 245 40
Old 07-24-2007, 08:48 PM   #273 (permalink)
Tim
non-Cilantrist
Tim's Avatar
That'd be a first, I think. And my guess is that it'd rub.
Tim is offline
Old 07-25-2007, 12:34 AM   #274 (permalink)
I hate you
ILL FG2's Avatar
AJ
a 235/40 might work... would probably still require some work on the fender lining.
"8thcivic.com where everyone holds hands, nutswings and paints everything in time attack fashion"
-Michael Bolton
ILL FG2 is offline
Old 07-31-2007, 01:35 AM   #275 (permalink)
saskwatch420's Avatar
Kevin
has anyone run anything with a 30mm offset or lower. I was looking into running 18x7.5 with a 30 or 22mm offset. Does anyone know if this will work. The tire would be 225/40.
I'm just curious, I still need to measure and see how close they are to sticking out of the fender. Otherwise if it's to far it will look stupid.
saskwatch420 is offline
Old 08-01-2007, 01:35 AM   #276 (permalink)
paolo's Avatar
would 17x7.5 +40 offset rub in EX?
would they be ok?
EX is the equivalent of the Civic sedan here in the Philippines.
TIA for the inputs.
paolo is offline
Old 08-01-2007, 06:55 PM   #277 (permalink)
aki
aki's Avatar
Resident Si Sedan Hater
+22mm will stick out of the fender. +30 will be flush, or slightly sticking out. The lowest on the site has been +20 w/ spacers, or +35mm w/o.
I'd suggest against it though, as lower offsets throw off your suspension geometry.
aki is offline
Old 08-02-2007, 04:29 PM   #278 (permalink)
can anyone tell me our civics bore size? i already know the bore size of my rims which is 73.1 . thanks..
Si_Jeff is online now
Old 08-03-2007, 12:09 PM   #279 (permalink)
BuddhaBoi's Avatar
Steve
Would you think 19" Volks GT-V would have fitting issues?
BuddhaBoi is offline
Old 08-06-2007, 03:05 AM   #280 (permalink)
MyZeR's Avatar
My
would 18x8.5 work? and what is the minimum offset for a coupe? 35mm?
MyZeR is offline
LinkBack to this Thread: http://www.8thcivic.com/forums/wheel-tire-upgrades/6934-wheel-fitment-recipe-wheel-offsets-work.html
18 This thread Refback 01-14-2008 12:34 PM
18 This thread Refback 01-14-2008 09:57 AM
18 This thread Refback 01-14-2008 08:21 AM
18 This thread Refback 01-14-2008 08:17 AM
Wheel Fitment Recipe - wheel offsets that work - 8th Generation Honda Civic Forum This thread Refback 12-10-2007 05:51 PM
