Wheel Fitment Recipe - wheel offsets that work - Page 11 - 8th Generation Honda Civic Forum
Closed Thread
LinkBack (10) Thread Tools Display Modes
Old 04-15-2007, 02:50 AM   #201 (permalink)
Sirbelch's Avatar
Paul
My bad. Full story. I had Drag Extream Alloys (came with car from dealer) 18x7.5 +45 with 225/40/18 that rubbed like a dog with its ass on the floor. I then bent one of those rims and had to get a new set. So I got Motegi Tracklite 1.0 17x8 +45 with 235/40/17 tire. So, with the new wheels, i have 1/2 more inches i can lower the car. So when my Tein Flexes get here and i lower more, the fenders will rub again so i wanted to know what to use to roll the fenders. My other post was a preemptive question so that i could take action before i lowered the car more. Good catch on that one. Sorry about the confusion. Hope this helped. I have an Si coupe.
Sirbelch is offline
Old 04-15-2007, 03:04 AM   #202 (permalink)
Tim
Tim's Avatar
http://www.rollyourfender.com/
Tim is offline
Old 04-15-2007, 09:34 AM   #203 (permalink)
Si4Life's Avatar
Whos High Pitch?
can we see pics with the motegi tracklites?
Si4Life is offline
Old 04-18-2007, 12:13 AM   #204 (permalink)
Sirbelch's Avatar
Paul
There are picks in the Intro/Pictures forum. The title of the thread is My Si (56k need not apply) and in the wheel tire section under Old Wheels vs New Wheels. There are 9 pictures in the intro one.
My Si (56K need not apply)
Sirbelch is offline
Old 04-18-2007, 06:36 PM   #205 (permalink)
tommyroo's Avatar
Where did you get your rims from? I've been trying to find some TRAKLITE w/ Gun Metal Machined Lip but only seem to come up with 4 bolt rims.
tommyroo is offline
Old 04-18-2007, 10:50 PM   #206 (permalink)
Sirbelch's Avatar
Paul
Tire Rack. 1594 and change shipped, mounted and balanced.
Sirbelch is offline
Old 04-19-2007, 01:24 PM   #207 (permalink)
tommyroo's Avatar
Thanks! A bit more then I planned on spending but I suppose I gotta do what I gotta do.
Question.
I have the stock SI 17" rims. The MOTEGI TRACK TRAKLITE 2.0 are listed as:
+45mm
Bolt Pattern: 5-114
Rec. Tire Size:215/45-17
**Lightweight: 14.6lbs.**
I have to buy new tires to fit these don't I?
Are there any other forged rims that are this lightweight that come in 17x7?
tommyroo is offline
Old 04-19-2007, 07:37 PM   #208 (permalink)
COMplex's Avatar
got e85?
Question.
+45mm
Bolt Pattern: 5-114
"Rec. Tire Size:215/45-17" = Stock tire size for Si.
Volk Te-37's are forged and 14ish lbs. Why do you want thin wheels?
COMplex is offline
Old 04-19-2007, 10:22 PM   #209 (permalink)
Sirbelch's Avatar
Paul
Those volks are like 450 a wheel aren't they? If i could afford the volks, i soooooo would have gotten those. I've been in love with TE 37 for years now. The tracklites are still forged so they are strong.
If you want to get a tire that has a different size than stock for a given wheel at the tire rack, you have to pick the tires first and then pick the wheels.
Edit: So i looked up 17" TE 37 on the Tire Rack and they are 613 PER wheel. So thats 2452 for a set before you even put tires on it. I also looked up the weight of the TE 37s and they are 15.5lbs where the Tracklites are 15lbs and they are a 1/2 in wider than the Volks.
Sirbelch is offline
Old 04-20-2007, 11:16 AM   #210 (permalink)
tommyroo's Avatar
Yeah I noticed that but got confused. How come the rim is 17x8 and yet the tires that fit them are the ones that go on my 17x7 rims?
tommyroo is offline
Old 04-20-2007, 03:10 PM   #211 (permalink)
ILL FG2's Avatar
AJ
because they're stupid... You can run a 225/45
ILL FG2 is offline
Old 04-20-2007, 04:39 PM   #212 (permalink)
Sirbelch's Avatar
Paul
You can run a 235 on a 8" wide wheel, A 225's side walls would lean in a bit. However a 225 on a 7.5" wide wheel fits great. Tire rack is dump some times. if you order your tire before the rim, you don't have to by a 215mm wide tire.
Sirbelch is offline
Old 04-20-2007, 05:43 PM   #213 (permalink)
Tim
Tim's Avatar
I wouldn't say that they're stupid. I'd say that they're playing it safe. If there's an OEM size tire that tirerack can recommend that Honda has already approved, why would they say otherwise and run the risk of being held liable?
Tim is offline
Old 04-21-2007, 12:08 AM   #214 (permalink)
ILL FG2's Avatar
AJ
Of course they're playing it safe. With that size and offset it would be pointless not to run a 225. Even if you were slammed it wouldn't rub on a 225.
ILL FG2 is offline
Old 04-22-2007, 11:54 PM   #215 (permalink)
Purpul Plane 4ever!
Nomar06's Avatar
18x7.5 50mm offset with 215/40/18, 1.5" drop from Tein SS coilover.
Already edited the first post with the info.
Originally Posted by mattsbobo View Post
Personally I like to wear my Ted Nugent-esque loincloth, grab my bow and arrows, and my half gallon of scotch then I go terrorize my apartment complex.
Nomar06 is offline
Old 04-23-2007, 12:41 PM   #216 (permalink)
UCLAMAN's Avatar
Do you guys think I won't be rubbing if I put in a 1.5" drop if I went with some Axis Reverbs 18x7.5 +42offset wrapped with 225/40 18's?
UCLAMAN is offline
Old 04-23-2007, 12:49 PM   #217 (permalink)
Purpul Plane 4ever!
Nomar06's Avatar
Should work since 18x7.5 45mm offset 225/40-18 (1.4" drop) was posted as this runs without rubbin.
Sorry if I didnt asnwer that in the PM. I got back from DC about 30mins before you PM'ed me.
Nomar06 is offline
Old 04-23-2007, 01:02 PM   #218 (permalink)
UCLAMAN's Avatar
ain't no thang man...i appreciate the help!
UCLAMAN is offline
Old 04-27-2007, 04:47 PM   #219 (permalink)
bhanleyjr's Avatar
Camber Kit?
Originally Posted by freeurmind69
my old rims... RH C2s 19x7.5
[(+44offset) FigiSi06 please correct my mistake.thx]
was running with 3mm spacers and still sunk into the fender too much
So i changed it to...this
NEW WHEEL FITMENT.
19x8 (+40offset) TSW vortex.
lower with TEIN SS w/2.25inches drop.
sits right with fenders in the front.
i believe the rear can go as high as 19x8.5 (+40offset)
Conclusion: 19x8 (+40offset) with 2.25inch drop will work.
Do you have a camber kit on that bad boy?
bhanleyjr is offline
Old 04-28-2007, 07:15 PM   #220 (permalink)
UCLAMAN's Avatar
New wheel in mind...
will 19x8 work? What would the difference be between +35 vs +45 offset with this size?
For the person above me runnin' 19x8's, does your +40 offset rub?
UCLAMAN is offline
Closed Thread
LinkBack to this Thread: http://www.8thcivic.com/forums/wheel-tire-upgrades/6934-wheel-fitment-recipe-wheel-offsets-work.html
Mags offset? - Club Civic Quebec :: Forum This thread Refback 08-28-2011 03:51 PM
Honda Club Brasil • Exibir Tópico - Qual off-set do New Civic? This thread Refback 08-07-2011 06:34 PM
8th Gen FAQ's index - Club Civic Quebec :: Forum This thread Refback 08-07-2011 10:03 AM
Fs: Rare Civic Type R Wheels (FD2R) - Beyond.ca - Car Forums Post #0 Refback 07-23-2011 05:12 AM
Fs: Rare Civic Type R Wheels (FD2R) - beyond.ca car forums community for automotive enthusiasts Post #0 Refback 07-04-2011 05:35 PM
18 This thread Refback 01-14-2008 01:34 PM
18 This thread Refback 01-14-2008 10:57 AM
18 This thread Refback 01-14-2008 09:21 AM
18 This thread Refback 01-14-2008 09:17 AM
Wheel Fitment Recipe - wheel offsets that work - 8th Generation Honda Civic Forum This thread Refback 12-10-2007 06:51 PM
Wheel fitment... Now maybe a problem DumbasSi Wheel And Tire Upgrades 26 04-27-2006 07:10 PM
Wheel offsets? Jake Wheel And Tire Upgrades 1 01-06-2006 01:35 PM
